Author Topic: Do Brake Discs Need Changing? [pictures attached]  (Read 3317 times)
Offline Nasir
« on: January 02, 2016, 12:14:52 pm »
Hi,
The brake pads at the back definitely need changing, however, I'm wondering if the discs also need doing. There is a very slight lip but otherwise the disc looks fine.
Rear discs
Front discs
Shadow Blue 2007 GTI DSG (Standard)
Offline dronners
Re: Do Brake Discs Need Changing? [pictures attached]
« Reply #1 on: January 02, 2016, 06:34:58 pm »
theres probably life left in them.  but whilst you got the ideal oppertunity in your hands..  it would make sense to just do it
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: January 02, 2016, 06:39:13 pm »
Have you checked the inner sides as they can be worse?.
Offline flashp
  • -Receive: 65
« Reply #3 on: January 02, 2016, 09:30:35 pm »
Measure their thickness. Start by comparing what you have to the current MOT requirements and see what you think.
Or take it to a trusted garage and get their opinion.
The photos don't look like either are worn to the point of needing immediate replacement though. Hard to tell from a photo .
« Last Edit: January 02, 2016, 09:32:48 pm by flashp »
Gone but not forgotten :-)
Offline flashp
  • -Receive: 65
« Reply #4 on: January 02, 2016, 09:34:03 pm »
If they are check your caliper mounting sleeves, they may be sticking.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: January 02, 2016, 09:54:46 pm »
I actually got ripped off when I bought my golf as the out looked good but inner were severely scored on both front and rear discs. stupid me didn't think I'd get robbed but I did.
Offline Nasir
« Reply #6 on: January 03, 2016, 12:07:12 pm »
Cheers for the replies fellas. Going to change the front pads and see about the rear discs when I get them off.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: January 03, 2016, 01:43:36 pm »
What's the minimal thickness on oem discs as this is stamped in them. the dealer will say replace them, mot stain should advise them and I'd say you can use them till your next pad change hopefully not sooner.
Offline Nasir
« Reply #8 on: January 03, 2016, 10:24:43 pm »
Not sure mate, haven't replaced them yet. I'll let you know when I do
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: January 04, 2016, 07:02:38 am »
Was thinking if someone else knew it would help you  :smiley:
« Last Edit: January 04, 2016, 09:19:57 am by r5gtt »
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=jp0uv0ljf2ipmbov3sqhoselqh&/topic,90967.msg917089.html#msg917089
« Reply #10 on: January 04, 2016, 07:25:25 am »
I think its
22 mm front
10 mm rear
05 | Tornado Red | DSG
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: January 04, 2016, 09:58:33 am »
If that is correct or close enought then I would say neither require replacing as they don't look like they've worn to that limit.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #12 on: January 04, 2016, 11:00:55 am »
Mine looked about the same.
These were the measurements. I replaced them anyway.  :stupid:
front 22.640mm
back 10.785mm
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: January 04, 2016, 11:18:13 am »
Lol fair enough. I'd go another round with them and change on the next pad change.
I've seen wafer thin ones on a car and wondered what would happen if they had snapped whilst braking. now that's dangerously  :stupid:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #14 on: January 04, 2016, 11:24:30 am »
I replaced with reasonably priced discs, hawk pads and super blue fluid. Only do 5000km a year so should be a while before i need to look at them again. Unless i go big.
