Author Topic: Led number plate lights  (Read 11718 times)
Offline Berry
Re: Led number plate lights
« Reply #15 on: January 17, 2016, 05:47:47 pm »
Ok cheers for that. So are the resistors easy to get hold of?
Shadow Blue MK5 GTI
Offline GTIEagles
« Reply #16 on: January 18, 2016, 09:16:28 pm »
I ordered a set of these for mine and they work perfectly, no bulb out errors or anything, I'm on an 05 plate though
Offline NikerGTI
« Reply #17 on: January 19, 2016, 08:42:50 pm »
what are the best for a mk6 gti?
Offline mk5Eire
« Reply #18 on: January 19, 2016, 09:28:48 pm »
I used buy the whole LED units off eBay, as opposed to just the bulbs . Excellent white light and lasted over a year.
http://www.ebay.ie/ulk/itm/310350020787
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #19 on: January 19, 2016, 09:54:24 pm »
X2.  Don't understand the point of the bulbs as they end up flickering, putting light out errors on dash and not even that bright.
Sent from my SM-G928F using Tapatalk
Offline Berry
« Reply #20 on: January 31, 2016, 05:42:48 pm »
Right guys, for those having trouble with comparability on those genuine VW LED units, I'd recommend these resistors;
http://www.ebay.co.uk/ulk/itm/281527246014
They seem to have used genuine Vag plugs too.
Worked a treat for mine. Now giving off a much better light, but crucially, they actually stay on.
Shadow Blue MK5 GTI
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #21 on: February 01, 2016, 01:50:17 am »
Only mk6s with older BCM (that can't be coded to LED) will need resistors with OEM LED license lamps. The mk5s are fine with the OEM LEDs.
Offline Berry
« Reply #22 on: February 01, 2016, 10:07:47 pm »
Hmmm that's interesting as they definitely didn't work on mine without the resistors...Unless you mean they can be fitted without resistors but have to be coded instead?
All witchcraft and wizardry to me!
Shadow Blue MK5 GTI
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #23 on: February 01, 2016, 11:33:23 pm »
Just to make sure, did you get genuine mk6 license plate LEDs?
Offline Berry
« Reply #24 on: February 02, 2016, 05:11:22 pm »
Yeah they were the genuine ones in the link at the start of this thread. Had all the VW stamps etc on them too.
Shadow Blue MK5 GTI
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #25 on: February 02, 2016, 06:56:01 pm »
http://m.ebay.co.uk/itm/252273557984
These shouldn't need any resistors in mk5. Weird if you had problems with them.
I didn't need resistors in both my Golfs and I know a lot guys who have them with no issues. You'd the first...
Offline bluebert92
« Reply #26 on: February 02, 2016, 07:23:06 pm »
I have installed a few of the CANBUS Leds into my unit untill summer when I can be bothered to change the units over for full LEDs, however whenever I go to turn them on I get a strange like buzzing sound and I get the error on the dash?
Offline Berry
« Reply #27 on: February 02, 2016, 07:28:42 pm »
Yep they're the ones Shoduchi.
In that case, thinking about it, perhaps it's due to the fact I'm only able to put one in, as the other side has a led numberplate light integrated with a reversing camera.. Which has always worked regardless.
Im wondering if, as it was only 1 LED light before, and the other side was a normal 'Festoon' bulb in the standard unit, there wasn't enough of a resistance discrepancy to throw a warning..? As I'm assuming the wiring for both lights are both on the same loom, does that make sense?
Shadow Blue MK5 GTI
Offline Berry
« Reply #28 on: February 02, 2016, 07:43:27 pm »
Probably total bull, sorry I know nothing about electronics!
Shadow Blue MK5 GTI
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #29 on: February 02, 2016, 08:06:56 pm »
Probably, it's a basic system. The resistors only provide the needed resistance to the circuit to not activate the bulb out error.
