November 15, 2024, 06:49:06 am
All Things Mk5
Performance Modifications
R32 tdi Y-pipe
Topic: R32 tdi Y-pipe (Read 1478 times)
sandypark1993
Just Arrived
-Given: 0
-Receive: 0
R32 tdi Y-pipe
January 07, 2016, 11:34:13 pm »
Does anyone know if blue flame or any exhaust companies make the y pipe for the tdi to go with the r32 rear bumper? Looking for just an off the shelf job
RetroRaz
Just look at my post count
-Given: 32
-Receive: 194
Re: R32 tdi Y-pipe
Reply #1 on:
January 07, 2016, 11:38:41 pm »
If you dont want to change your exhaust, you can always buy a r32 style rear bumper without the exhaust cutouts. Will cost less than buying the oem r32 rear bumper and the exhaust
Sent from my SM-G928F using Tapatalk
#RetroRaz -
https://instagram.com/retroraz/
jason_rmh
Won't Shut up.
-Given: 69
-Receive: 81
Re: R32 tdi Y-pipe
Reply #2 on:
January 08, 2016, 07:36:24 am »
You will probably need to get one made. Start by finding out the diameter of the pipe that joins to the back box.
I think it's 55mm on the 140 tdi.
Exhaust fabricators can usually get a pre made Y adapter which they will then weld up to the tail pipes of your choice.
Jas
VCDS (Preston, Lancashire)
sandypark1993
Just Arrived
-Given: 0
-Receive: 0
Re: R32 tdi Y-pipe
Reply #3 on:
January 11, 2016, 08:24:00 pm »
i want the r32 look tbh. and my golf is a tdi 170 which could maybe be bigger than a 140? and aint sure on where to buy the y pipe direct from or the tips?
All Things Mk5
R32 tdi Y-pipe
