Author Topic: Tail light output uneven/poor  (Read 1733 times)
Offline dom069
« on: January 09, 2016, 02:46:09 pm »
Hello,
I've got a niggling issue which is annoying me a bit. I've got R32/Ed30 rear lights on my Gti and the tail light output is uneven around the cluster, hopefully the pictures below highlight the problem.
My question is...has anyone come across this before? I've had a look at the bulbs and they are Osram and look ok to me, is it likely to be the bulbs? Is it an issue with the clusters themselves?
Excuse the mucky car, it will be getting a clean tomorrow :ashamed:
BC Racing Coilovers : R32 Rear Bumper : Milltek Cat Back : R32 Rear Lights : S3 Brakes : Colour Coded Side Skirts : US Grill : 18" BBS CH : De-Wipered : Bluefin Remap : Pipercross Filter : S3 Short Shifter : Powerflex Wishbone Bushes : MK6 Steering Wheel : RCD510
Offline v4rley
  • -Receive: 104
Re: Tail light output uneven/poor
« Reply #1 on: January 09, 2016, 03:14:31 pm »
Have you tried swapping the bulbs around to see if it the bulbs?
Otherwise I would guess it's been changed in VCDS.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: January 09, 2016, 04:36:57 pm »
I'd try a set of standard bulbs first off as the bulbs sound suspect.
Offline dom069
« Reply #3 on: January 09, 2016, 05:03:33 pm »
I'll have a play with swapping bulbs tomorrow. I'm not sure how it could be changed using VCDS though?
The bulbs are standard ones, I tried some LED ones which were even worse so reverted back to standard. I might pick up some replacements just to make sure though.
Offline v4rley
  • -Receive: 104
« Reply #4 on: January 09, 2016, 05:15:22 pm »
It's somewhere is VCDS. Think it's central electronic 09. Can adjust either brake or sidelights, it's done as a percentage.
If you cannot find it let me know and I'll have a look
Offline dom069
« Reply #5 on: January 09, 2016, 09:58:15 pm »
I'll have a play with VCDS tomorrow then. Cheers  :happy2:
Offline dom069
« Reply #6 on: January 10, 2016, 05:49:04 pm »
Ok, had a play with VCDS earlier, I turned them up in 10% increments. It got to 60% (started at 20%) and it looked like this:
They looked too bright and still weren't even, I was also a bit concerned that the brake lights wouldn't be obvious enough in daylight, I turned them back down to 40% and then my battery died! An RAC visit and £122 later I got a chance to look at them at 40%:
Quality of the pictures isn't great but in the dark the lights look fine.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: January 10, 2016, 06:16:02 pm »
Looks much better now.
Offline dom069
« Reply #8 on: January 10, 2016, 06:51:41 pm »
Yeah it does. Big thanks to @v4rley for pointing me in the direction of vcds :drinking:
Offline v4rley
  • -Receive: 104
« Reply #9 on: January 10, 2016, 08:55:56 pm »
Pleased you made some progress, although it cost a new battery!
