Author Topic: Screeching noise  (Read 6897 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Screeching noise
« Reply #15 on: January 12, 2016, 06:12:45 pm »
Nice one Mitch  :happy2:
That sounds like a vacuum leak?. anyone second this?.
Offline Mitch1980
« Reply #16 on: January 12, 2016, 07:38:02 pm »
Gearbox bearing ?
Offline doylebros
« Reply #17 on: January 12, 2016, 07:57:27 pm »
Sounds like a failing PCV to me.
Offline doylebros
« Reply #18 on: January 12, 2016, 08:00:38 pm »
Offline FoleE
« Reply #19 on: January 12, 2016, 08:22:40 pm »
My car used to screech/squeal briefly on deceleration or occasionally when it was idling. Replaced the PCV as mentioned above and it cured the problem  :happy2:
Offline Mitch1980
« Reply #20 on: January 12, 2016, 09:26:52 pm »
Offline Mitch1980
« Reply #21 on: January 12, 2016, 09:27:46 pm »
Found this
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #22 on: January 12, 2016, 10:08:11 pm »
I did type to take the dipstick out but network kept on throwing me out. As doylebros said and posted a link so he was correct.
pcv failure.
Offline Mitch1980
« Reply #23 on: January 12, 2016, 10:11:06 pm »
Not 100% yet but does sound similar I'm still taking it back to amd just to clarify thanks to all all you hopefully this is it God knows how much it will be be got to be cheaper than dsg failed
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #24 on: January 12, 2016, 10:14:03 pm »
Start the car and wait for the noise??? then pull the dipstick out  :happy2: simple.
Offline Mitch1980
« Reply #25 on: January 13, 2016, 09:53:35 am »
Yep it does when I pull out stick it stops and sounds like it's going to stall engine but if I buy a Pcv delete will that stop noise or will I still have to buy a new Pcv
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #26 on: January 13, 2016, 10:24:48 am »
Probably cheaper or as cheap to buy the latest PCV from VW or TPS. Don't bother with a delete unless you go the whole hog and buy a full PCV delete Vent-to-Atmosphere kit from R-Tech
The latest PCV valve will be fine and will last many thousands of miles, the early/original parts were a lot more prone to failure
Offline Mitch1980
« Reply #27 on: January 13, 2016, 11:46:43 am »
