Author Topic: Running sub/amp from the RNS510, anyone?  (Read 21963 times)
« on: January 04, 2010, 03:16:19 pm »
anyone done it? is there a definitive guide to creating a lineout?  :happy2:
Re: Running sub/amp from the RNS510, anyone?
« Reply #1 on: January 04, 2010, 03:19:09 pm »
There are lineouts shown on the back LO-R, LO-L and the Earth.
Never done it or seen it done. It might be down to you being a Pie 'n' Ear VC.  :wink:
Offline t20lau
    • Website design Sheffield
« Reply #2 on: January 04, 2010, 03:24:50 pm »
Can you get a picture of the rear of the rns?! Just want to see what Hedge is refering to...
SEAT Ibiza Sport | Vauxhall Astra VXR | BMW Z4 M-Sport | VW Golf GTi Edition 30 | BMW F30 330D X-Drive
« Reply #3 on: January 04, 2010, 03:32:44 pm »
i want to get the pie out and an rns in its place  :grin:
but fear the loss of the sub, and i simply dont understand the witchcraft that is car/audio electrics
i'll get up in the loft later and take a shot of the back of the rns
Offline BenR
« Reply #4 on: January 04, 2010, 04:40:44 pm »
I have a sub and amp run from my  RNS510 unit, i had to buy an adapter for the back of the unit not sure what it does but i think it enables an RCA to be run from the back of the unit.
I had it done at Source Sounds in Sheffield: 0114 2571550
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: January 04, 2010, 05:00:45 pm »
Probably quite simple to make your own lead.
Use the connections on the back, connected with a couple of repair wires and soldered into some RCA type female connectors.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: January 04, 2010, 05:08:53 pm »
Or this little baby -
http://www.sextonsdirect.co.uk/ict/p~30-108.html?cat=0
From another website -
« Last Edit: January 04, 2010, 05:13:18 pm by vRStu »
Stu...
« Reply #7 on: January 04, 2010, 06:17:11 pm »
8 quid = bargain.  :smiley:
« Reply #8 on: January 04, 2010, 06:20:30 pm »
^^^ that looks to be within my skillset  :smiley:
soldering and physically making one isnt an option for me...if i actually want it to work  :laugh:
so that is something i can simply plug into the back or the rns and then add the cables that are currently in addition going into the back of my pioneer?
thankyou for the link btw  :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #9 on: January 04, 2010, 06:22:25 pm »
The only 'difficulty' might be that you already have a plug in that location so you need to swap the wires from one plug to another.  Pretty simple tbh.
Stu...
« Reply #10 on: January 04, 2010, 06:26:43 pm »
cool, gunna order one and then panic about the next stage when it arrives  :drinking:
EDIT: £5.99 delivery!  :stupid: does is come gift wrapped in gold leaf  :chicken:
must only be a small jiffy envelope surely
« Last Edit: January 04, 2010, 06:29:45 pm by Very Cherry »
« Reply #11 on: January 04, 2010, 07:33:45 pm »
Its because its going all the way to Cornwalland.  :wink:
Offline Lyons
  • -Given: 18
« Reply #12 on: January 05, 2010, 09:36:46 am »
Bugger, i sold my amp and sub on Sunday because i didnt think it was possible to run an amp off the RNS.
Offline mclovin
« Reply #13 on: January 14, 2010, 11:58:05 am »
One problem with that connector is it doesn't have a remote amp output, so although you can get an RCA signal out of the unit you have no way of turning the amp on with the stereo. You could get around this by wiring the remote input on the amp to some sort of switched +12V when you fit it, but it's not a great solution. I used a Line Output converter with a remote amp output to hook up an amp to my RNS-510 and the results are really impressive, but it is a bit of a fiddly job...
Offline Rob GTI
« Reply #14 on: January 14, 2010, 12:59:28 pm »
If you spliced into the connector labelled amp in Monte's photo here:
http://www.mk5golfgti.co.uk/forum/index.php?topic=10662.msg163296#msg163296
Would that give you a remote swtich for the amp?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
