Author Topic: Rear Wiper Again!  (Read 3845 times)
Offline zayd
Rear Wiper Again!
« on: January 15, 2016, 06:51:45 pm »
My rear wiper sprays but will not wipe.
Is it most likely to be the motor that's packed up in there?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Rear Wiper Again!
« Reply #1 on: January 15, 2016, 07:27:02 pm »
Hello there,
I'd open the boot and check the wiring under the rubber grommet at the top left hand side for chopped/cut wiring.
Offline zayd
« Reply #2 on: January 15, 2016, 10:00:42 pm »
I've already repaired this a few months ago by soldering in some new wire and heat shrinking the repair.  A brown earth wire had snapped but all others were fine.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: January 15, 2016, 10:10:00 pm »
Oh yes we had this convoy before lol
Have you checked the wiring again?.
Offline zayd
« Reply #4 on: January 15, 2016, 10:37:59 pm »
Not yet, as I couldn't believe it could be this again. What about the right hand rubber conduit? Do you know the wiring in that one control.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: January 15, 2016, 10:50:26 pm »
That should be the right hand side light wiring if I'm correct.
Offline SI-R32
  • -Receive: 126
« Reply #6 on: January 16, 2016, 07:25:56 am »
The right hand one is for the aerials and the washer tube,  all the lights,  lock and motor are in left hand side
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: January 16, 2016, 11:32:53 am »
My bad  :ashamed:
Offline zayd
« Reply #8 on: January 17, 2016, 10:20:06 pm »
Right then.  I found the culprit!
It's the boot lock that's playing up and not correctly reporting its closed position to the wiper motor.  I tested this theory by activating the rear wiper and then opening the boot and manually locking the lock with my fingers.  Then lowering the boot a little, it activated the wiper and it swept in its full motion correctly.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: January 18, 2016, 06:45:56 pm »
Really wow that's surprising  :confused:Glad you've found the culprit.
Offline zayd
« Reply #10 on: January 19, 2016, 12:00:44 am »
Apparently they are another item that go faulty and especially on the early cars. Mines an AXX engine.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: January 19, 2016, 12:07:58 am »
Mine is that BWA engine so not sure whether early or not. Have you now sorted the problem?.
Offline zayd
« Reply #12 on: January 19, 2016, 11:37:15 pm »
I'm gonna fit the part on Saturday and will report the outcome.  Hopefully, it will be sorted after that.
Offline zayd
« Reply #13 on: January 23, 2016, 01:01:46 pm »
Replacement latch didn't fix the problem with the rear wiper.
Honestly, I've come across so many post on various forums about this becoming faulty and many people give up and either delete it or just live with it not working.  I'm getting to that point too.  Funny thing is that no faults show up in VAG COM for this part.
Maybe its the wiper motor itself, that's playing silly buggers.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: January 23, 2016, 10:54:22 pm »
Only way to find out is replace the bugger mate?.
