Evening folks.
Rather irritating problem has raised its head on the Golf. Had the car MOT'd on Monday and naturally, a side light bulb failed nearly straight after - so, replaced both with LED replacements from Halfords, the brighter white appeals rather than the piss stained yellow look. (They're non xenon units i should add).
So replaced both side lights now none of them work? They come on briefly when the car is started but extinguish after maybe 5/10 seconds? The yellow warning light is lit on the dash also?
I've checked the fuse diagram but it really doesn't make much sense, the handbook (if i'm reading it correctly) states there should be a fuse in a certain area but it doesn't appear to be there? Can anyone help? Do these cars not like LED's? It was LED bulbs that came out of it so i'm really stumped as to what it is!
I've phoned a local specialist but i'd rather ask around these parts first!
Thanks guys!
Dan
