Author Topic: Mystery vacuum line  (Read 2007 times)
Offline Hannakournikova
Mystery vacuum line
« on: January 16, 2016, 03:35:27 pm »
So noticed a vacuum line cable tied up. Followed it to to under the engine cover. Will have a further nosey with the rain stops.
Any ideas?
Re: Mystery vacuum line
« Reply #1 on: January 16, 2016, 03:44:30 pm »
And photos
Offline Chris92
  • -Given: 33
« Reply #2 on: January 16, 2016, 04:34:23 pm »
Looking at where it's coming from I'd say it's a vac pipe for a boost gauge
« Reply #3 on: January 16, 2016, 05:10:56 pm »
went outside and braved the cold to investigate. Seems to go down towards the turbo.
Offline Chris92
  • -Given: 33
« Reply #4 on: January 16, 2016, 05:45:30 pm »
Probs running through the bulk head down there
« Reply #5 on: January 16, 2016, 08:07:06 pm »
Though the grommet would be higher up. Needed to check canbus tomorrow so will have a nosey.
Offline GTI-Pirelli
  • -Receive: 27
« Reply #6 on: January 16, 2016, 09:09:30 pm »
Do you know if you definitely have an OEM diverter valve on the turbo?
Forge units operate using a vacuum that would follow that route between the valve and the intake manifold. Or as others have said for a boost gauge.
Obviously not my image. The pipe running from the vacuum tap (lower right of the manifold) and cable tied to the metal pipe (fuel rail?).
2017 Audi S4
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: January 16, 2016, 09:15:07 pm »
I was also thinking that but didn't know how this was possible until now hahaha
« Reply #8 on: January 16, 2016, 09:27:56 pm »
where is DV located?
that the one best accessed by removing drivers wheel?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: January 16, 2016, 09:34:39 pm »
Yes it's meant to be on out k03 turbos. ko4 have them in you're face like a 5 minute job to replace lol
Yours may have a lovely relocation kit fitted but you'll need to take the engine cover off and take a picture for someone to say yay or nay.
