Author Topic: Little crimp connectors that are used for centre electrics module.  (Read 2901 times)
Offline ollie288
Does anyone know where I can get the above from?
They are the little crimps that push in and lock. Used in the quad lock on the radio as well.
Cheers :happy2:
Re: Little crimp connectors that are used for centre electrics module.
« Reply #1 on: January 05, 2010, 12:06:24 am »
They are repair wires. You can get them from Vw. I guess you are running a wire so you can enable your xenon shutter?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: January 05, 2010, 03:37:35 pm »
Repair wires from the dealers, normally about £1 each which will give you two ends.
Not a full list but some handy numbers here -
http://www.nsxjr.com/Audipins.html
Stu...
Offline ollie288
« Reply #4 on: January 05, 2010, 06:04:25 pm »
No that has been done a while ago.  :smiley:
@everyone - I need just the end crimp so I can reattach it to an existing wire.
On the heated seat loom one of the crimps snapped, I need to cut that of and re-crimp another one on but dont have any spare!
Thanks :happy2:
Offline ollie288
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #6 on: January 05, 2010, 06:11:57 pm »
You need the proper tool to crimp those on properly.  That's the idea of the repair wire - Inline crimp or make a soldered connection to your existing wire.
I don't think Maplin will have them, I've scoured the net trying to find a good supply.  I just use the repair wires now.
« Last Edit: January 05, 2010, 06:13:42 pm by vRStu »
Stu...
Offline ollie288
« Reply #7 on: January 05, 2010, 07:10:08 pm »
Thanks vRStu, I'll get a repair wire from VW then.
Cheers  :happy2:
