Author Topic: Electrical Fault  (Read 826 times)
DubaiGTI
Electrical Fault
« on: January 20, 2016, 09:15:32 am »
Hi All,
I run a 2009 Mk5 and have two weird electrical faults:
1. When I start the car I receive an error message (and headlight warning light on the left dial - speedo) that my front right main beam is not working - even though the headlight is working fine.
2. When I drive the GTI at night when the headlights are on if I put the main beam on, open or close a window, use the horn, turn the fog lights on there is a millisecond loss of power where everything cuts off. It is literally a millisecond but nevertheless it is unsettling and only happens when I am driving with the headlights on.
Anyone experienced these faults before and can advise on how to fix?
Many Thanks
Offline Nasir
Re: Electrical Fault
« Reply #1 on: January 20, 2016, 10:56:38 am »
Check wiring to the headlights. I assume they are Bi-Xenon, judging by your name and standard spec there?
Shadow Blue 2007 GTI DSG (Standard)
