Author Topic: URGENT HELP NEEDED CODING  (Read 3453 times)
Kam88
« on: January 21, 2016, 07:56:16 pm »
HELP NEEDED
Fitted my power fold mirrors with puddle lights to my golf mk5 today and just needs coding i do have my own VCDS but i am useless with coding.
Anyone local that can help me i am located near UXBRIDGE??
Or can walk me through it on the phone would really appreciate it guys
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: URGENT HELP NEEDED CODING
« Reply #1 on: January 21, 2016, 08:01:31 pm »
HELP NEEDED
Does the helper window not come up?   It should help you with what numbers to add in the code according to the equipment you have
Sent from my SM-G928F using Tapatalk
Kam88
« Reply #2 on: January 21, 2016, 09:00:17 pm »
HELP NEEDED
@RetroRaz
To be honest i don't get any of it i can do the bit with long code helper quiet easy  :signLOL:
anything else absolutely clueless any chance giving me a hand ??
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: January 21, 2016, 09:47:03 pm »
Did you also replace the wing mirror switch?.
No one gonna help you bro  :signLOL:
« Last Edit: January 21, 2016, 09:50:59 pm by r5gtt »
Kam88
« Reply #4 on: January 21, 2016, 10:29:03 pm »
Yeah replaced it  :signLOL:
Managed to figure it out myself someone could of just said to add the numbers together had to dig around for hours till i came across a thread on a US forum
Kam88
« Reply #5 on: January 21, 2016, 10:32:02 pm »
@Eddie-NL
Any chance with some help i managed to figure out the coding part i so like to think  :signLOL:
Fitted power folding mirrors with puddle light and dim drivers mirror
Coded the puddle light works perfect
Coded power folding and comes up with what i remember Code 31 Error i think ??? what does that mean ???
Also the Dim part does that have to be coded or will that work automatically ???
Also reverse dip mirror my one has 7 pin connector does that mean it will never work as its not fitted with it??
Any help be great
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: January 21, 2016, 10:41:17 pm »
Would this be of any use to you?.
This is the coding that you will need as VCDS doesn't know about these controllers as of latest non beta release.
+2 - Puddle Light Active
+4 - Mirror Turn Signals
+16 - Automatic Run Active
+32 - Mirror Heater Active
+64 - Door Exit/Warning Light Installed
+128 - 5 Door Chassis
+256 - Seat Memory Installed
+512 - Right Hand Steering
+4096 - Folding Mirrors installed
I ended up with the following codings as I have puddle, door exit and folding mirrors.
Driver - 4854
Passenger - 5110
Kam88
« Reply #7 on: January 22, 2016, 06:17:13 am »
Driver - 4854
Passenger - 5110
I had Driver +4790 for puddle and folding but error came up might try yours later.
what is Automatic run active ?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: January 22, 2016, 10:56:37 am »
Do you have internal door illumination?.
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #9 on: January 25, 2016, 10:37:43 pm »
@Kam88 - did you manage to solve this? Just wondering as I want to do a similar swap on my ED30 and figured the coding is the trickiest bit!
Edition 30 - no. 1387
Kam88
« Reply #10 on: January 26, 2016, 06:17:42 am »
PMd @Dave J
