Author Topic: Edition 30 Exhaust Size  (Read 9645 times)
Offline irish_ram
  • -Given: 200
« on: January 21, 2016, 08:51:08 pm »
Probably  a dumb question but then I am pretty dumb when comes to exhausts but can anyone tell me what the pip diameter size is off the part of the exhaust that connects into the Muffler/Backbox
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Edition 30 Exhaust Size
« Reply #1 on: January 21, 2016, 09:52:17 pm »
65 mm
Offline irish_ram
  • -Given: 200
« Reply #2 on: January 21, 2016, 10:00:15 pm »
65 mm
Cheers mate so roughly 2.5 inches which others have confirmed also.
Do you know where I can find a decent pic of the exhaust as googled and cannot find. Reason being I am getting a custom R32 Y pipe made up but need to confirm how it will fit on in place of the backbox
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: January 21, 2016, 10:27:06 pm »
You'll be very lucky as there are around three that I've seen and one looks well dodgy  :signLOL:
Go for the third pictured one  :happy2: :signLOL:
« Last Edit: January 21, 2016, 10:32:51 pm by r5gtt »
Offline irish_ram
  • -Given: 200
« Reply #4 on: January 21, 2016, 10:33:25 pm »
Sorry don't get what you mean as in Mayne three and dodgy?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: January 21, 2016, 10:35:39 pm »
pardon me it's phone typo errors.
there maybe around three pipes I've found as pictured. if that's what you're looking for. That's how they fit in place from what I've seen so far irish_ram.
« Last Edit: January 21, 2016, 10:37:29 pm by r5gtt »
Offline irish_ram
  • -Given: 200
« Reply #6 on: January 21, 2016, 10:40:43 pm »
I mean I am not too worried about the actual Y pipe itself as getting it made from a good source in stainless steel etc.
My worry is connecting it to the existing exhaust as in where does the backbox connect up, on a straight or curve and is it clamped or welded
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: January 21, 2016, 10:44:19 pm »
if you look at the thrifty picture mate, you'll notice the Y part joins to a darker shaded pipe is. where the oem exhaust fits  :happy2:
I bought a car back system and it looked just like that where the two sections meet up and join together.
Offline irish_ram
  • -Given: 200
« Reply #8 on: January 21, 2016, 10:49:56 pm »
Ah yes so welded on but at an angle so my Y pipe inlet would need to cure rather than be straight. Plus I need to make sure I get a Y pipe that has all the brackets welded to hold it in place
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: January 21, 2016, 10:53:26 pm »
It is going to be touch and go as them is isn't a simple task.
Yes your Y pipe will need a curve and yes you need brackets attached but they are bent to specific requirements as you can see from that picture I sent you. I've seen someone try and manufacture a pipe with brackets and it was the worst thing I'd seen in a long time.
Maybe the guys where you're having the Y pipe made can help you?.
Offline irish_ram
  • -Given: 200
« Reply #10 on: January 21, 2016, 10:55:02 pm »
Yeah I need to send them a pic of the above and see what they say.
Offline irish_ram
  • -Given: 200
« Reply #11 on: January 21, 2016, 11:02:44 pm »
Getting the Y pips welded to the oem is not a problem but the brackets to hold it and how accurate they need to be are making me think this is not worth it  :confused:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: January 21, 2016, 11:03:54 pm »
No worries, let us know how you get on with it.
Only problem being the brackets and how they will be once done.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: January 21, 2016, 11:05:03 pm »
They will need to be spot on to look good or they'll juat look tacky and bent or not aligned mate.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: January 21, 2016, 11:18:40 pm »
Have a word with nige at bcs power valve and see if he'll sell you some brackets as with these you can bolt the pipe on to the other side and fit the brackets on the rubbers from the garage who can then weld them on to spec   :happy2:
http://www.powervalve.co.uk/products/vw/golf/mk5/golf-mk5-gti-edition-30-2004-2007-r32-style-centre-exit/vw001-cat-back-system-choice-of-trims-system-options-sports-system.html
