Author Topic: DSG remap question  (Read 5153 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
DSG remap question
« on: January 23, 2016, 03:38:08 am »
What version of software most DSGs have in the Edition 30? Does the version of the software relate to any hardware difference, i.e., an older software version means a weaker clutch?
I've seen that APR only remaps Exx and Fxx DSGs. Are Cxx as strong as those? 405 lbft/550 Nm a safe value for all?
@rtechniki @R-tech-Nick @vRSAlex @Keith@APR
Thanks for your help.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: DSG remap question
« Reply #1 on: April 12, 2016, 07:43:00 pm »
Found out on Facebook that Fxx are the worse to remap and make sure they don't slip. :smiley:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: April 14, 2016, 10:40:29 am »
I saw the same thing on TFSI tuning FB page.
Offline Paradox1
  • -Given: 41
« Reply #3 on: April 15, 2016, 11:13:30 am »
How cam you tell which code box you have?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #4 on: April 15, 2016, 12:20:19 pm »
Only a tuner can tell when they connect to the box and do a remap, I think. I only knew after my tuner told me mine was a Cxx.
Offline flashp
  • -Receive: 65
« Reply #5 on: April 21, 2016, 11:15:04 pm »
Mines been ok so far. When I had my LSD fitted it was discovered that I had Mk6 transmission on 2009 car. No idea what version that is though...
Gone but not forgotten :-)
Offline Paradox1
  • -Given: 41
« Reply #6 on: April 22, 2016, 11:50:12 am »
As we are on the subject of DSG mapping, what can I expect from a dsg map?
I understand it will stay in gear in sports more and shift quicker but tbh its pretty instant shifting in stock form. isit really worth it?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #7 on: April 22, 2016, 01:04:48 pm »
Mine needed the torque limiter changed to make remap work well. The box was "cutting" the ignition timing, preventing the engine to make more power and torque.
Offline Paradox1
  • -Given: 41
« Reply #8 on: April 22, 2016, 01:22:02 pm »
Ahh I see, thanks.
Once your car DSG has been mapped is there any change is tone? just curious
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9 on: April 22, 2016, 01:28:11 pm »
Ahh I see, thanks.
The engine sounds raspier and quicker to respond to the throttle input but I think that it's just related to the increased boost and fuelling, nothing related to the DSG remap itself.
Offline flashp
  • -Receive: 65
« Reply #10 on: April 22, 2016, 02:13:41 pm »
Ahh I see, thanks.
I had a full set of Revo engine mounts done and that changed power delivery and engine noise in the car. You can feel the engine vibrations (only just) through your fingers on the wheel at idle. The engine is restrained in it's mounts so there is no inertia generated by soft mounts to overcome when on the throttle. These engines move around a lot on stock mounts. On a modified car that's driven OE mounts are worked very hard. The noise in the cabin is very addictive, creates a 'growly' engine noise.  I love it, some may not. Car is very sharp on the throttle though.  :happy2:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #11 on: April 22, 2016, 02:58:26 pm »
Yeah, I forgot about those. I've only upgraded both dogbone's mounts to Vibra-Technics and that made a good difference to the engine response. My Eddie only has 38.500 miles so I think the top engine mounts are still ok. When they're a bit more tired, I'll upgrade them as well. Thank you for your input to the topic! It's always high quality. :happy2:
Offline Beej
« Reply #12 on: April 22, 2016, 09:16:48 pm »
Ahh I see, thanks.
I have been told that having it mapped reduces if not totally eradicates the farts/pops on gear change. One of the reasons why I haven't went with one, as I like having that when your giving it some!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #13 on: April 22, 2016, 09:32:26 pm »
Ahh I see, thanks.
I haven't seen any video with a DSG remapped and no fart at gear change. Mine keeps farting, the more boost the merrier, but I know it wasn't much changed so far (most likely just the torque limiter...).
Offline Beej
« Reply #14 on: April 22, 2016, 09:33:05 pm »
Ahh I see, thanks.
I haven't seen any video with a DSG remapped and no fart at gear change. Mine keeps farting, the more boost the merrier, but I know it wasn't much changed so far.
Have you got a dsg remap?
