Author Topic: Dash Lights After Highline Install  (Read 4995 times)
Offline Lyons
  • -Given: 18
Re: Dash Lights After Highline Install
« Reply #15 on: January 28, 2016, 10:08:24 pm »
@RetroRaz I had the temperature and fuel needles off before I fitted the clocks and notice now that I mustn't have put them back in the right place as they are a few mm to the left when the car is both up to temperature and with a full tank.
If I remove the clos from the car to dismantle and fix the needles will the lights come back on after I get them reset? Or will the lights only appear for the first time after new clocks are installed?
Am I right in thinking once coded to the car the can be removed and refitted without issue too?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #16 on: January 28, 2016, 10:10:26 pm »
Hey
You will get the abs and esp lights, just go for a drive around 25mph and they should clear off themselves
Sent from my SM-G928F using Tapatalk
Offline Lyons
  • -Given: 18
« Reply #17 on: January 29, 2016, 08:43:45 am »
Offline neiller
  • -Given: 32
« Reply #18 on: February 03, 2016, 12:02:34 pm »
Did you get this sorted ?
Sent from my SM-N9005 using Tapatalk
Offline Lyons
  • -Given: 18
« Reply #19 on: February 03, 2016, 05:05:08 pm »
Yes thanks.
