Author Topic: 18x8.5 wheel size, what are the drawbacks?  (Read 1687 times)
Offline oisinc
« on: January 23, 2016, 07:20:08 pm »
So I really like the TD 1.2's but would like them without the writing around the edges. So 1.3;s it is..
But they only come in 8.5 width  not available in 8inch.
So what are the complications of this?
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: 18x8.5 wheel size, what are the drawbacks?
« Reply #1 on: January 23, 2016, 07:25:58 pm »
You should still be ok if you stick to 225 40, assuming they're et45.
Offline Johnsy
« Reply #2 on: January 23, 2016, 07:28:09 pm »
I think VWR wheels are unbranded TD 1.2's, but carry a premium .
Can't comment about n the wider wheel though, but interested he people's thoughts also, I was thinking about running a wider trackday wheel , subscribed
Offline oisinc
« Reply #3 on: January 23, 2016, 07:37:19 pm »
@ AJP I presume the ET would be correct for the MK5 gti as Ill be buying them through the Group Buy the Demon Tweeks are currently running here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,103370.0.html
So a wider tyre is a no go?
thanks
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #4 on: January 23, 2016, 07:44:58 pm »
Et45 is pretty much flush with an 8 inch wheel and 225 width tyre.
8.5, there's 6/7mm more poke from the wheel, but keeping the 225 over say a 235 should just clear. Depends if you're lowered, and by how much!
Offline oisinc
« Reply #5 on: January 23, 2016, 08:05:05 pm »
car is completely stock..
But I have a set of PSS10's for it. :)
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #6 on: January 23, 2016, 08:52:59 pm »
I reckon you'll be ok. I'm 30mm down on H&R springs, BBS VZ which are 8 wide, et44 with 225 40 18s. It's nowhere near close to rubbing, even with hard driving.
Adding 6-7mm of poke to the wheel but staying with 225 width tyres would be negligible at 30, 40, or probably 50mm drop.
I didn't get the details of the TDs but from memory they're et45 so the rule above applies.
No issue running 225 40 tyres on 8.5 rims by the way. It's barely any more stretched than a 7.5 or 8 in reality.
