Author Topic: Suspension mods recommendations per RedRobin's reviews  (Read 8863 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Suspension mods recommendations per RedRobin's reviews
« Reply #30 on: January 28, 2016, 12:41:27 pm »
It's my belief that it may be best to install all 3 mounts at the same time so as to ensure a balanced restraint across the whole engine and transmission assembly at all of the connection points. It may be possible to increase the loading on the remaining oe parts if only one is done. Something to consider.
I agree. I just don't want the extra noise and vibrations since it's my daily driver when my wife needs the GT Sport. When the OEM mounts are dead (which will happen sooner than normal) I can just replace them for the same parts. :smiley:
  • -Receive: 679
« Reply #31 on: January 29, 2016, 09:42:03 am »
Another agreement here!  Doing the dogbone on it's own really punishes the LH gearbox mount and movement from that one feels more noticeable with a beefed up dogbone.  The driver's side is quite robust and seems to stand up to it. It's also the LH gearbox one that transmits most of the noise and vibration. Gearboxes are rough, noisy things.
What the car needs is a 4th mount at the front, connected to a cross member.  That's what the MK1 had and the engines in that car never flapped about like they do from MK2 onwards.  Some cars use hydraulic dampers (like mini struts) to help but I've never seen them on German cars.
  • -Receive: 801
« Reply #32 on: January 29, 2016, 11:32:26 am »
They do a hydraulic damper for the mk5... I think youd have to import one from the US, fits next to the OEM 'dogbone' mount between the subframe and engine.
  • -Receive: 679
« Reply #33 on: January 29, 2016, 04:41:50 pm »
Got any links as I can't find any info on it?
  • -Receive: 801
« Reply #34 on: January 29, 2016, 05:09:30 pm »
Google "mk5 engine torque damper"
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #35 on: January 29, 2016, 06:50:51 pm »
http://newrunperformance.blogspot.com.es/search/label/mk5gti
developed the engine damper on the target fo Goaf MK5 GTI.  :signLOL:
05 | Tornado Red | DSG
