Author Topic: Putting R32 front calipers on an Ed30  (Read 5188 times)
Offline PhilNUK
  • -Given: 32
« on: January 24, 2016, 10:54:48 pm »
What would I need I  order to get r32 front calipers to fit to my ed30?
I have found calipers...  Just wondering about disc size and spacers etc...  Anything I need to worry about?
Offline Beddie
  • -Receive: 76
Re: Putting R32 front calipers on an Ed30
« Reply #1 on: January 24, 2016, 11:19:07 pm »
Assuming you have the calipers and carriers then the only thing you'll need is brake lines and discs,
No spacers required for the R32 calipers (even on 17" Monzas) and disc size you can use either the 345mm R32 disc or the 340mm Audi TTS version
Carbon Grey Edition 35 - Here
« Reply #2 on: January 24, 2016, 11:23:57 pm »
Might have to change the front flexi pipes
Offline PhilNUK
  • -Given: 32
« Reply #3 on: January 24, 2016, 11:47:46 pm »
Thanks for the replies
So a disc and pad set like these would be fine? Or are there a disc brand I should avoid? http://pages.ebay.com/link/?nav=item.view&id=251439362780&alt=web
Offline PhilNUK
  • -Given: 32
« Reply #4 on: January 25, 2016, 12:22:09 am »
Just seen this set on eBay which is tempting as they are refurbished brembo with discs and lines with them but am I right in saying these are for the rear?
http://pages.ebay.com/link/?nav=item.view&id=271942697407&alt=web
Edit: spoke to the seller and they are for the front with EBC discs and pads
« Last Edit: January 25, 2016, 10:25:44 am by PhilNUK »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #5 on: January 25, 2016, 01:04:29 pm »
That's an alternative to the R32/S3/TTS calipers. It's lighter but it isn't cheap, keep that in mind as well. You might also need to run spacers with most OEM wheels.
If you go for the R32 calipers I'd advise fitting Brembo Sport 340 mm TTS discs. Almost 2 kg lighter than the OEM 345 mm discs (I did that with my GT Sport). :wink:
Offline PhilNUK
  • -Given: 32
« Reply #6 on: January 25, 2016, 03:00:53 pm »
Thanks for the reply
When you say it isn't cheap you mean the cost of those on ebay or further costs I am not taking into account?
I don't mind paying £600 for a kit with it all in if I know they are good and will be a decent set.. I have seen R32 calipers only going for £3-400 and am accounting for £150 for discs on top of that and then pads and lines etc.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #7 on: January 25, 2016, 03:57:13 pm »
I think you can get the discs cheaper. That kit uses 312 mm discs which are smaller than the Brembo Sports 340 mm I got for 75 £ from Amazon a couple of months ago. Right now they cost around 115 £, I think. You can also check oscaro.es/oscaro.fr, they make great prices for both discs and pads.
Not sure what pads that kit uses. Good enough R32 pads can cost around 100 £, but there might be cheaper available. Braided lines from HEL cost around 35 £ for those calipers.
Offline PhilNUK
  • -Given: 32
« Reply #8 on: January 28, 2016, 01:25:14 pm »
right.... just to clarify
If I bought these http://pages.ebay.com/link/?nav=item.view&id=271942697407&alt=web
would they be a significant upgrade on the standard edition 30 brakes?
The fact that the discs they use are smaller than other calipers is that a sign they aren't as good as brakes with the bigger discs?
Just need clarification before buying! I really would like a set of brembos as have had brembos on my bikes but with cars I am a bit stuck as to whats what. I want a big brake set up and don't want to fork out to find they aren't any better than what I have currently
cheers!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9 on: January 28, 2016, 04:34:23 pm »
That kit seems similar to the NQSBBK: http://www.mk5golfgti.co.uk/forum/index.php?page=mods&mod=20.
It's not a BBK but I think they're a better solution to the Ed. 30 and R32 brakes. Make sure you're not paying too much for them.
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #10 on: January 29, 2016, 08:21:27 am »
I purchased some TTRS calipers refurbished by them, asked for a custom job with custom decals. They were crap and I got a refund.
#1493
Offline omeydz
  • -Receive: 50
« Reply #11 on: January 29, 2016, 05:18:59 pm »
Think I have had TTRS calipers from that seller and fitted them for my mate. Bleed nipples and hose threads and paintjob were poor and threads rounded leaking air.
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #12 on: January 30, 2016, 06:18:18 pm »
Paint job was piss poor. They hadn't been fully refurbished. A very average diy spray job at that. The calipers leaked fluid in transit killing the paint. The bubble wrap left imprints in the paint which hadn't been left to harden effectively. The laquer over the decals was literally so thin the decals were already peeling. I posted pics up on here once I got them.
I'd only recommend calipers refurbished by BCR. A full proper solution.
#1493
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #13 on: January 30, 2016, 06:37:46 pm »
Just to clarify (and so I can avoid them when I upgrade mine) are we talking about gbautomotive2010 on ebay?
