Author Topic: H&R hubcentric 8mm vibrations  (Read 1800 times)
Offline spb
« on: January 25, 2016, 11:01:45 am »
Hi,
I must be the only one that get vibrations from the hubcentric H&R 8mm spacers. I looks like the chamfered edge of the spacer is bigger than the wheel bore so is not a perfect fit. In other words if I take the wheel and spacer off and try to put the spacer in the wheel bore is not going in the whole way on all the surface. The spacers have also a sign of wear exactly in the chamfered area.
I got them new... part no 1655571.
What do you think is happening here? Should I get new ones? Did someone else had such issues? :sad1:
Offline ephemeross
  • @supptora
Re: H&R hubcentric 8mm vibrations
« Reply #1 on: January 25, 2016, 01:44:59 pm »
I think you may have the wrong ones.
http://www.amazon.co.uk/1655572-TRAK-Wheels-Spacers-112/dp/B005K8VNEO
Those are the correct ones I believe.
nvm they're MK6, forgot to filter my search :p
This is the site I used when finding the part number for mine, https://www.dpmperformance.co.uk/car-parts/volkswagen/golf/buy/wheel-spacers
Their prices are good, but found them slightly cheaper on amazon.
Also before fitting use a wire brush on the hub/wheel to make sure it's free from dirt, rust, etc.
« Last Edit: January 25, 2016, 01:50:03 pm by ephemeross »
2007 Reflex Silver GT TDI 170 @ 187 BHP / 313 lbft.
Instagram: @supptora
Offline spb
« Reply #2 on: January 25, 2016, 01:52:17 pm »
Offline ephemeross
  • @supptora
« Reply #3 on: January 25, 2016, 02:22:22 pm »
Specs are correct, not sure if those specific ones are a different design due to them being for an Eos and not a MKV?
http://www.dcperformance.co.uk/cheap/780552/volkswagen/h_r-trak%5E-wheel-spacers/1655571.html
Maybe they're the same :S Odd.
Did you get the correct length & type of bolts, and did you torque them to 120nm?
« Last Edit: January 25, 2016, 02:30:02 pm by ephemeross »
Offline spb
« Reply #4 on: January 25, 2016, 03:01:12 pm »
http://www.eeuroparts.com/Parts/82782/Wheel-Spacer-Set-8mm-1655571/
GTI is listed there
I think we can rule out. I'll clean the hubs...
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #5 on: January 26, 2016, 08:36:24 am »
Again, correct length bolts? Chamfered edge face going inward to clear radius of the hub? I have H&R 8mm spacers I used to run with stock wheels and never had an issue with them....so cannot comment on solving this for you.  :confused:
Offline spb
« Reply #6 on: January 26, 2016, 11:21:26 am »
Long bolts but I'll double check on Saturday when I plan to clean the hell out of those wheels, hubs and spacers. I'm pretty much sure this is the issue here....
