Author Topic: Best head unit  (Read 5827 times)
Offline Mitch1980
Best head unit
« on: January 25, 2016, 06:32:24 pm »
Any recommendations on head unit must have sat nav ,iPod connection ,would like one that is easy to install and that won't drain the battery.would also like one with blue light option so it matches the standard blue dials and hopefully one that have a Vw start up screen .any recommendations please
Offline numec
Re: Best head unit
« Reply #1 on: January 25, 2016, 06:45:03 pm »
Kenwood dnx series?
Offline theminty1
Re: Best head unit
« Reply #2 on: January 26, 2016, 11:56:31 am »
Alpine w925. Connects 2 fitting kit. Polo 6R DAB mount + aerial. Sorted  :happy2:
140 BKD GT TDi  5dr
Offline Jonnyed30
Re: Best head unit
« Reply #3 on: January 26, 2016, 05:20:07 pm »
Are the above mentioned head units better that a rns510. Is there any advantage to go with an aftermarket one over oem. Sorry to jump in but I'm in the market for a head unit too and unsure which route to take. Thanks
Offline theminty1
Re: Best head unit
« Reply #4 on: January 27, 2016, 08:40:03 am »
It depends on what you actually want. Going aftermarket will make your car a potential target for thieves. If you are unhappy about that stay OEM. The Alpine does have a removable portion. Aftermarket also allows you to expand your system in the future. Aftermarket will be more expensive you want nav etc. There are different fascias available. The VW one looks the best and not expensive.
Do some snooping on the net to help you out :)
140 BKD GT TDi  5dr
Offline Jonnyed30
Re: Best head unit
« Reply #5 on: January 27, 2016, 09:31:21 am »
Thanks for the advice I hadn't actually thought about the risk of thieves. So the rns510 is the better bet. Which is the best version and is there one to avoid I see so many versions of it for sale on eBay it can get a little confusing knowing what's what.
Offline Greenman
  • Life is not a straight line!
Re: Best head unit
« Reply #6 on: January 27, 2016, 10:55:37 am »
Does anyone know if the RNS510 has RCA outputs for an amp?
Steel Grey 2006 Mk5 GTI - R-TECH Stage 1 (268bhp/334ftlb) - BCS Cat Back - Pre-Cat Delete - Carbonio Panel Filter - Rev G DV - 18" BBS CH - Leather - RNS510 - Colour Coded Bumpers and Skirts - ED30 Front Splitter - Eibach Sportlines - Open Fog Grilles - Wind Deflectors.
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
Re: Best head unit
« Reply #7 on: January 27, 2016, 02:03:32 pm »
I'd say one of the Pioneer's or Kenwood DNX series
I'm personally going to go for one of Pioneer's when funds allow.
Couldn't fault the double DIN one I had in my Astra.
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
Re: Best head unit
« Reply #8 on: January 27, 2016, 02:31:48 pm »
If ipod connection is important id recommend testing it out first.  I bought a Kenwood ddx4015 a while back, and its ipod integration is crap.   It's very slow - changing tracks takes ages as there is a pause every time you press a button.  Scrolling through artist and album is also painful.
Offline mk5Eire
Re: Best head unit
« Reply #9 on: January 27, 2016, 03:20:21 pm »
If your getting the rns510 be aware of issues with battery drain on pre 2007 cars. For the new versions of the rns I think you need an updated canbus gateway. A quick search on here and I'm sure you'll find a couple of threads on it
Sent from my iPhone that holds battery for 48 minutes
Re: Best head unit
« Reply #10 on: January 27, 2016, 03:27:24 pm »
Nope.
Re: Best head unit
« Reply #11 on: January 27, 2016, 03:33:42 pm »
Nope.  You'll need an Aux loom and take the signals from that.
In my 2007 Ed30 I've got an RNS510 revision Q, which has anti-drain software in it.  Didn't need a newer gateway.  You might need a newer gateway to get track names and things appearing on the highline dash though, not sure.  I don't care about that stuff.
Offline Jonnyed30
Re: Best head unit
« Reply #12 on: January 27, 2016, 03:43:45 pm »
So if iv got an 08 car some of the radios may still not be a straight plug and play jobbie?
Offline mk5Eire
Re: Best head unit
« Reply #13 on: January 27, 2016, 03:58:05 pm »
Your car being 2007 you more than likely got away with it. I was mainly referring to 2005,2006 cars i know for certain people have experienced battery drain after installing the rns510.
Depends what headunit you are upgrading to. Many are plug and play and have canbus software built in to avoid battery drain.
Offline Jonnyed30
Re: Best head unit
« Reply #14 on: January 27, 2016, 04:23:15 pm »
Cheers for the info very helpful mate
