October 19, 2024, 01:21:39 pm
All Things Mk5
How to Guides / Troubleshooting
Miss fire / engine management light !!
Topic: Miss fire / engine management light !! (Read 1875 times)
Markis236
Always Involved
-Given: 1
-Receive: 1
If in dout boost it out !
My Ride:
January 25, 2016, 07:24:00 pm »
Ok guy this is my first post on the forum since I joined and unfortunately it's a problem !
So I got my self a mk5 golf gti (200ps) so the problem is I was driving home from work today and the car basically shat it's self ! Basically what I mean is it's now miss firing like f*ck ! Feels like the car is running on 2 cylinders with the engine management light flashing ! Pulled over and done some checked (oil and water) and I have no idear what the problem is ? I doe a coilpack recall on Friday but because I can't drive the car to vw they say I can't get the coilpacks unless a vw engineer fits them for warranty reasons ? I was wondering if anything else can cous this done some reading and it could be a few things #1 coilpacks #2 carbon deposits on inlet valves #3 bad plunges (changed 2000 miles ago) or #4 carbon deposits on the injector ? If any one else has had symptoms like this any info do would be great :)
Thanks Mark.
Andy
Admin
Just look at my post count
-Given: 39
-Receive: 442
Re: Miss fire / engine management light !!
Reply #1 on:
January 25, 2016, 07:40:23 pm »
Welcome to the forum,Sounds like coil packs what you described,if your in the aa etc get them to recover it
gttdi build thread
r32 build thread
Markis236
Always Involved
-Given: 1
-Receive: 1
My Ride:
Reply #2 on:
January 25, 2016, 08:07:09 pm »
Thanks for the replay bud phoned a friend with a fault code reader going to find which cylinder is misfiring and try switch the coilpacks around and pray it's just a coil down miss my baby all ready haha
shoaybmakda
-Given: 25
-Receive: 54
Reply #3 on:
January 25, 2016, 10:49:30 pm »
Had a similar issue and after replacing coil packs and spark plugs turned out was a injector on cylinder 2 missfire.
Markis236
Always Involved
-Given: 1
-Receive: 1
My Ride:
Reply #4 on:
January 26, 2016, 06:49:22 am »
Was luck it is clylender 4 coil down swapped it with 2 and it's now number 2 down so it's just a coil haha it's trying to get the car to vw on Friday for the coilpack recall its booked in for haha
anorganix
Reply #5 on:
January 26, 2016, 07:45:09 am »
If I were you, when changing the coils I'd also change the spark plugs.
A set of NGK BKR7EIX go for about £30.
All Things Mk5
