Author Topic: Checking the CAM BUS Gateway version  (Read 1049 times)
Offline lewishoward
« on: January 27, 2016, 10:40:33 am »
Hi everyone,
I’m hoping someone can help me…
Ive just purchased an RCD 510 DAB radio but I have read about potential battery drain after installation. My car is a 2007 GTI so I want to check the CAM BUS Gateway to see what version it is as I've heard I need a version ‘K’ or newer.
My question is do you have to remove the CAM BUS Gateway module to read the version or can you see from it in situ? If I do have to take it out can I remove it and put it back straight after i've read it? Or is this going to cause problems!
The other option I suppose is to install the RCD 510, then waiting and see if I get battery drain…And if I do buy a newer CAM BUS Gateway module and get it coded through VCDS.
Sorry to be naive, this is all new to me!
Thanks!
Offline neiller
  • -Given: 32
Re: Checking the CAM BUS Gateway version
« Reply #1 on: January 28, 2016, 06:41:21 am »
I was able to see mine when I took the little cubby beside the drivers right knee and popped out the small fuse panel ! Can't remember weather or not I could read the numbers on it if you can get to some1 on the vcds register they'll be able to see Straight away for s few beer tokens
Sent from my SM-N9005 using Tapatalk
