Author Topic: Retrofiting mfsw steering wheel  (Read 10360 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Retrofiting mfsw steering wheel
« Reply #30 on: February 01, 2016, 09:19:18 pm »
Another little tip that I like to use is to put a marker pen line on the head of the bolt each time it had been re-tightened. A simple way of keeping track how many times it has been off  :happy2:
Is that 5 times  really true or can we just put some fresh Loctite blue on the threads
I wouldn't see an issue with loctite  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #31 on: February 02, 2016, 05:48:08 pm »
@RetroRaz and @Newbieintown thanks guys for all your help and support for helping with my retrofit CC now all working perfectly  :smiley:
Offline hugo
« Reply #32 on: February 08, 2016, 07:01:10 pm »
Hi update on my retrofit!
I changed over the control module CH one, and also mf botton airbag wire.
I got the 3 yellow lights and I tried to code it and nothing is working, even the horn dosent work! Do I need a different slip ring?
Will try to code it again tomorrow.
I have s 06 gti manual, high line display. Rns510 also fitted
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #33 on: February 08, 2016, 07:45:26 pm »
What code have you entered in? I think all GTI's had a type 2 slip ring so you should be ok. Sounds like a coding issue
Sent from my SM-G928F using Tapatalk
Offline skard
  • -Receive: 245
« Reply #34 on: February 08, 2016, 07:48:26 pm »
Is it a mk5 wheel with a loom part number starting 1K0, or a mk6 wheel with a 5K0 loom?
Offline hugo
« Reply #35 on: February 08, 2016, 08:11:56 pm »
It's a mk5 steering wheel. I'll try again tomorrow as got some free time to try and code it
Offline hugo
« Reply #36 on: February 08, 2016, 08:18:17 pm »
I have 0001534 and I changed it to 0002534 but didn't accept
Then I tried 0001734 it accepted but nothing changed
Offline skard
  • -Receive: 245
« Reply #37 on: February 08, 2016, 10:05:58 pm »
Can you confirm the part number of the airbag loom you fitted?
Or did this come with a used wheel?
Offline hugo
« Reply #38 on: February 08, 2016, 10:55:02 pm »
Hi the air bag loom is 1k 0971584c
I bought it separate
Offline skard
  • -Receive: 245
« Reply #39 on: February 08, 2016, 11:25:36 pm »
Good that is the correct loom anyway.
That coding looks weird for mk5 16-steering, what was your original coding? Have you followed a coding guide for a mk6 wheel as that is different.
Is your car a manual and do you have cruise control? Try 0002022
What was the part number of your old steering module? Sometimes the slipring needs changed too
« Last Edit: February 08, 2016, 11:31:45 pm by skard »
Offline hugo
« Reply #40 on: February 09, 2016, 12:31:28 am »
I hope it's just the coding!
Well the standard code is 0001534.
The car is manual, no cruise control.
The steering wheel is the standard one that came with the car
I just adapted the mf buttons to the wheel.
The original sw control module I think it ends in c but I'm not sure need to
Check tomorrow ( it's in the garage )
Offline hugo
« Reply #41 on: February 09, 2016, 11:38:20 am »
Hi just been to the car to do more coding and everything is good I had
0001534 changed to 0001134 and all good.
Thanks for all the help guys
Much appreciated
