Author Topic: RCD510 / CAN Gateway ?  (Read 1359 times)
Offline lewishoward
« on: January 30, 2016, 06:19:38 pm »
Hi everyone,
I've heard of the battery drain problems after installation of RCD510 if the CAN gateway is too old. So I plugged my car into VCDS today and found out my CAN gateway version ends with the letter 'K'. My question is has anyone else installed an RCD510 with a 'K' version CAN gateway? And if so did you experience any battery drain?
Would be great to hear from you!
Offline lewishoward
Re: RCD510 / CAN Gateway ?
« Reply #1 on: January 30, 2016, 11:04:35 pm »
Part number is 1K0 907 530 K
Version is H04 0020
Anyone got this can gateway and successfully installed a RCD 510 with no battery drain?
Thanks!
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #2 on: February 01, 2016, 01:54:18 am »
http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
You need a newer CAN or someone who knows how to flash a newer firmware to avoid the battery drain. Not sure if your CAN can be flashed, though...
Offline Pashka
« Reply #3 on: February 04, 2016, 07:26:10 pm »
I could supply or flash your gateway, but the problem is to get the files needed for flash. I think I have more than 10 gateway which could be flashed, but all files are with same sw  :signLOL:
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
