Author Topic: DV and Cam Valve  (Read 831 times)
Offline irish_ram
  • -Given: 200
DV and Cam Valve
« on: January 31, 2016, 06:44:41 pm »
So I will be getting a rev g and replacement cam valve(connector snapped) and was wondering can I check anywhere with VCDS if these parts are affecting the running of my car.
Reason I ask is when I scan nothing comes up on VCDS but I am presuming doing some say measuting block tests would tell me if there is something still wrong wit them. Also this would then allow me to compare the results once I have replaced each part so I know if they have made a difference
Cheers  :happy2:
Offline dronners
Re: DV and Cam Valve
« Reply #1 on: January 31, 2016, 07:09:53 pm »
well dump valve you'd want to measure boost levels for any drops.  cam valve i assume would effect the timing advance
Offline irish_ram
  • -Given: 200
« Reply #2 on: January 31, 2016, 07:24:37 pm »
Cheers,
Yeah I inspected the DV the other week and it looked fine but is D revision and new one will be a G so wanted to make sure I could get evidence it had improved performance.
And with the cam valve the connector was broke and flagged an error but after I glued it back on the error has gone but again may be affecting the car in some way
