Author Topic: Valve stem Seals on 2007 GTI  (Read 2557 times)
Offline Mego
« on: January 31, 2016, 07:54:15 pm »
Hi all,been having bluish smoke issue while going downhill when off gas,and when i push the gas a little a bluish puff of smoke came out and then disappear.
i did change the turbo and nothing changed..then i did a full pcv delete and same problem is still there..yesterday i did a compression test wet and dry and all is ok (153,150,150,148).
my question is could this be a bad valve stem seals?is it known that seals go bad in tfsi engines?
i think the only option now is the valve stem seals.
BR
Offline Ricky123
  • -Receive: 27
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98436.0.html
Re: Valve stem Seals on 2007 GTI
« Reply #1 on: February 05, 2016, 10:21:07 pm »
I wouldn't like to say it's 100% not the stem seals but it's unlikely.
Never heard any issues with them even on really high mileage.
What engine oil are you running? When was the car last serviced? I'd be looking at everything else before the valve stems.
Spark plugs
Coil packs
Oil in boost pipes
There's loads to be looked at. Also get a full read with VCDS
56 mk5 ed30 3dr
57 mk5 1.9 TDi match
22 a3 s-line competition 45 tfsiE
09 Suzuki GSXR 1000 (road going track sl*g)
