Author Topic: Need Ur Help..Video Of my car while smoking on deceleration..  (Read 2003 times)
Offline Mego
« on: February 02, 2016, 04:15:54 pm »
Hi There,,
been trying to figure out my car problem before start to work on my engine..turbo is fine after being checked by 2 turbo guys..did a full pcv delete and didnt help..hope u can help me before i start to change valve stem seals as its the most possible cause as i have been told..
compression test is done and done all all ok..dry starting cyl1 153,150,150,148 wet 160,160,165,157
here is the video
Thank you.
Re: Need Ur Help..Video Of my car while smoking on deceleration..
« Reply #1 on: February 02, 2016, 04:47:52 pm »
Compressions are a little low, but not horrendous.  Around 180-190psi on a new engine.
That does look like classic valve guide wear.  Loads of over-run, followed by smoke when back on the gas.  That isn't a lot of smoke though.  I bet a lot of GTIs do that on such long hills and people don't realise.
Offline Mego
« Reply #2 on: February 02, 2016, 06:00:10 pm »
Thx for ur answer..my smoke issue started after fitting a catless dp and going stage 2 remap..seems oem dp was hiding smoke..why u said guides not seals?
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #3 on: February 03, 2016, 02:50:14 am »
There are both seals and guides on the valve stems.
Valve stem guides:
There are seals for both intake and exhaust valves. The exhaust valves get hotter and their seals differ from the intake seals to withstand the extra heat:
« Last Edit: February 03, 2016, 02:52:56 am by ROH ECHT »
Offline GTI-MATT
  • GTI-MATT
« Reply #4 on: June 23, 2016, 08:19:11 am »
Any update/fix with this problem mate?
Offline jez_monkey
    • GTINI
« Reply #5 on: June 29, 2016, 02:46:50 pm »
What he said - my jetta has started doing this just after fitting a de-cat exhaust system
