Author Topic: Strange ticking noise on '06 Gti. Only on idle  (Read 8997 times)
Offline raz469
« on: February 03, 2016, 05:06:25 pm »
Hi guys, i hope you can give me some good news, but yesterday after work the car started making a ticking noise, but only on idle. Its not made this noise before, and i kinda hope it because of the car didnt run for 9 hours. It made the noise all the way home (~20miles) but when i parked up it stopped. I think its the circled item below as i could see it rattle, but thought someone here would know.
Has anyone heard of this ticking? Or know what the below item is?
Thanks in advance
R
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Strange ticking noise on '06 Gti. Only on idle
« Reply #1 on: February 03, 2016, 05:51:01 pm »
Now that would be your auxiliary fan belt tensioner.
Get a 15mm long spanner on it and pull towards you to see if it is free as it contains a spring load for the belt.
Whilst stationery, rev the car gently with bonnet open or get someone to do that for you and have a listen for the noise as that shouldn't make a ticking noise.
That engine bay looks different to mine as the battery is located behind the headlight and mine is located at the rear where your header tank is  :confused:
« Last Edit: February 03, 2016, 05:57:10 pm by r5gtt »
Offline raz469
« Reply #2 on: February 03, 2016, 06:10:53 pm »
Thanks mate. Would sh*t have to come out to get it changed?:s
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: February 03, 2016, 07:06:51 pm »
No mate, just the tensioner itself and the belt would need to be refitted of course  :happy2:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #4 on: February 03, 2016, 07:25:47 pm »
You got some sort of racing battery fitted?
As above though, most likely AUX pulley, tensioner or ALT.
I replaced my alternator a few weeks ago for a second hand one from ebay £20 with pulley, spins fine and bearings good too, at that price mad to buy new; easy DIY. :happy2:
Offline skard
  • -Receive: 245
« Reply #5 on: February 03, 2016, 07:30:05 pm »
I have changed a few alternator pulleys over the years, easy to change with a tool like http://www.ebay.co.uk/ulk/itm/262127529746
I have found GSF car parts stock the original INA pulleys for a better price.
« Last Edit: February 03, 2016, 07:33:50 pm by skard »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: February 03, 2016, 07:51:44 pm »
Is that even a golf as the fuse box is missing  :scared:
Offline skard
  • -Receive: 245
« Reply #7 on: February 03, 2016, 07:59:02 pm »
I guess it is a Google image pic mixed with some Paint skills
Offline doylebros
« Reply #8 on: February 03, 2016, 08:13:31 pm »
This will help to prove if it's the alternator drive pulley -https://m.youtube.com/watch?v=fyosuYbPxr4
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: February 03, 2016, 10:52:18 pm »
Probably as golf tfsi engine bays and slam panel do not look like that  :signLOL:
Offline raz469
« Reply #10 on: February 03, 2016, 11:14:00 pm »
Thanks everyone for the advise. Gonna try sort it out this weekend with a mate weather permitting. @r5gtt that was from the net. But the tensioner was in the right place so didn't even notice the fuse box.
@scottymon. Funny you say that. I dont think so, the previous owner did change the battery and coil packs which I couldn't 100% understand why. The batt is a varta, nt sure of the rating
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: February 03, 2016, 11:17:19 pm »
@raz469 I think Scottymon meant the one from the picture where we got confused buddy  :wink:
coolio hope you figure the issue out and get it sorted  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: February 07, 2016, 02:08:30 am »
Bump
Offline Hooton
« Reply #13 on: February 07, 2016, 06:26:33 pm »
I have the same problem, changed all belts and tensioners and still got the rattle
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #14 on: February 07, 2016, 06:47:59 pm »
Check your alternator?.
Are you losing any coolant?.
Possible timing belt tensioner rollers or water pump?.
Have you checked your fuel pump cam follower as it maybe showing signs of failure which will result in fuel pump failure or even worse cam lobe failure!!!
Good to check it all or try get someone to have a look.
