Author Topic: Non-OEM reverse camera for Jetta (working and with photos)  (Read 5460 times)
Offline Rob.
« on: February 03, 2016, 09:20:49 pm »
Can you guys recommend me a half-decent reversing camera for a Mk5 Jetta?
I've got a Kenwood head unit (soon to be upgraded, hopefully) so I don't need OEM integration.
Are any of the eBay ones respectable?
« Last Edit: February 28, 2016, 11:58:04 am by Rob. »
Offline kingraza27
Re: Non-OEM reverse camera for Jetta
« Reply #1 on: February 04, 2016, 02:25:59 pm »
I have got this http://www.ebay.co.uk/itm/170-WIDE-ANGLE-VEHICLE-FRONT-REAR-VIEW-CAMERA-REVERSING-PARKING-CAR-CAM-OUTSIDE-/111759925570?hash=item1a05692142:g:BSUAAOSwu4BV5W61
Works like a charm.
I did not want to sacrifice a number plate light so I went for this mini one. One of the best things I have done to my car.
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #2 on: February 04, 2016, 06:51:12 pm »
Works like a charm.
Where abouts did you put it? I'm In the market for a camera and looking for ideas on locations
Offline kingraza27
« Reply #3 on: February 04, 2016, 08:54:51 pm »
Right there!  :laugh:
Offline TAPPY
  • -Receive: 56
« Reply #4 on: February 04, 2016, 09:27:56 pm »
Sweet cheers mate
Offline Rob.
« Reply #5 on: February 04, 2016, 10:27:18 pm »
For some reason I'd thought number plate type ones were the only option! Great shout.
Offline shoaybmakda
  • -Receive: 54
« Reply #6 on: February 07, 2016, 11:13:33 am »
i assume this wouldn't work with an RNS 510?
Offline TAPPY
  • -Receive: 56
« Reply #7 on: February 07, 2016, 12:04:46 pm »
I wouldn't have thought so as I don't think the RNS 510 has the RCA input for this type of camera
Offline Rob.
« Reply #8 on: February 07, 2016, 04:48:44 pm »
At the moment, think I might go for one of these (£11 on eBay) and drill a hole next to the number plate lights. Figured I can give it a touch of paint, then bung the hole if the camera is removed.
Although, would that make a bit of easy path for thieves?
Offline kingraza27
« Reply #9 on: February 07, 2016, 10:43:08 pm »
When i did mine, it was a easy job.
Hole is useless to thieves, i super glued mine PURELY, because i didnt want it to rotate. As i have made reference points and  if it moved, everything would get screwed for me. Hole is 2cm for camera FYI*
Offline Rob.
« Reply #10 on: February 28, 2016, 11:57:45 am »
Got this in and working yesterday  :laugh: (excuse the dirt...only washed the car last week!)
The downward viewing angle makes the ruler lines pretty useless, but it's plenty good enough for my daily reverse-parallel park into stupidly small spaces. It's barely visible from behind, which is what I wanted.
Thanks @kingraza27  :congrats:
Offline phas3r
Re: Non-OEM reverse camera for Jetta (working and with photos)
« Reply #11 on: March 12, 2016, 11:23:03 am »
Any links for ebay ones that work with rns510?
Will it automatically show the camera display in R gear?
08 MKV GTI DSG shadow blue
Engine: Revo Stage 2 7-3-9 | Forge Twintake | S3 Intercooler | R8 Coils | APR RSC MK6 Catback + 3" DeCat Downpipe
Brake/Susp : Golf R 345mm Front | Michelin PS4 225/40/18 | BBS CO VZ033 18" | H&R Rear ARB | S3 Lower Arm Bush
Interior: RNS 510 | 9WZ | Retrofitted CC | MK6R Rev Cam | Midline cluster :(
Offline MrVW1589
  • Eat Sleep VW
« Reply #12 on: May 01, 2016, 08:08:11 pm »
Same question for me really....Anyone know of a cheap one which fits the rns510?!
Offline Vwgtiking
« Reply #13 on: June 18, 2016, 03:25:41 pm »
@Rob. Can you show me where and how you wired this up in your Jetta?
Offline Rob.
« Reply #14 on: June 19, 2016, 08:48:40 pm »
I wanted to run it through the original rubber in the boot, but couldn't make it work  :sad1:
It's tucked inside the bootlid metalwork, then runs alongside the rubber to the car body, across the underside of the parcel shelf then down the driver's side sill to the head unit.
