Author Topic: Aftermarket HU - Which fakra cable should I buy?  (Read 4707 times)
Offline dk16
« on: February 05, 2016, 10:54:45 am »
My Golf MK5 uses the diversity system with double Fakra connectors (mustard colour and white). I purchased an aftermarket Chinese HU recently and with the HU came an unamplified double fakra cable. The company sent me a single amplified fakra cable which isn't working very well. AM signals are non existant and FM signals seem to drop out quite a bit.
Does anyone have any experiences with these and can anyone recommend me a decent cable to sort this out? I'm aware that I may never see stock signals but anything is better than I currently have.
Are these Ebay cables any good?
http://www.ebay.co.uk/itm/Twin-Dual-Double-Fakra-Antenna-Ae-rial-Adaptor-Adapter-ISO-Lead-Cable-VW-AUDI-/231409983992?hash=item35e11c21f8:g:RKIAAOSwiCRUfrfJ
Or do I need to spend more and get one of these?
http://www.caraudiodirect.co.uk/ct27aa25-aerial-antenna-dual-fakra-din-adaptor
Offline An0NyMOUs
  • A Nuisance
Re: Aftermarket HU - Which fakra cable should I buy?
« Reply #1 on: February 05, 2016, 12:18:07 pm »
I've got the eBay cable that you've listed. Does the job just fine
2.0 FSI 4motion
Offline dk16
« Reply #2 on: February 06, 2016, 11:52:04 pm »
Thanks mate, I shall order and see how I get on. :)
Offline dk16
« Reply #3 on: February 07, 2016, 01:49:13 pm »
Another question. I need to power the stereo's backlight buttons using the illumination wire (orange). Is there a cable/wire/feed I can tap into on the heater control unit that will only give power when the headlights/sidelights are switched on?
Offline mk5Eire
« Reply #4 on: February 07, 2016, 02:03:59 pm »
You may also have to run an ignition switched live so that the head unit will turn on and off with the turn of the key, otherwise you will have to do it manually every time. Common way to do this is to tap into an empty slot in your fuse box that's ignition live and run a cable back to the HU.
Alternatively you could splice into the cigarette lighter which is another switched live. Possibly could power the stereos backlights for you Aswel but not 1000% sure on that. I sold my mk5 a few months ago and can't remember if a light comes on around the cig lighter when your turn on the headlights. If it does, your laughing!
Sent from my iPhone that holds battery for 48 minutes
Offline An0NyMOUs
  • A Nuisance
« Reply #5 on: February 07, 2016, 02:04:21 pm »
If you don't mind spending a few ££ then go for this (its got a switched live on it too, if you need it);
http://pages.ebay.com/link/?nav=item.view&id=250960090221&alt=web
I can't help you with tapping into a wire as my stereo is just a screen and I don't need illumination
2.0 FSI 4motion
Offline An0NyMOUs
  • A Nuisance
« Reply #6 on: February 07, 2016, 02:06:55 pm »
I tried the cigarette lighter, couldn't find a decent switched live. I used the fuse box;
2.0 FSI 4motion
Offline mk5Eire
« Reply #7 on: February 07, 2016, 02:10:02 pm »
Yes fuse box always seems to be the better option of the two.
Offline dk16
« Reply #8 on: February 07, 2016, 11:39:33 pm »
Thanks for the info guys. Actually, the Chinese stereo I bought came with a canbus connector which has an illumination and acc feed on it. The illumination feed has constant power for some reason so the backlight buttons were originally constantly powered. I switched this over to the red acc cable for now so that the button lights only come on when the key is turned.
I was just wondering if there was a way to tap into a source that only receives power when the headlights are turned on. I know some people have said to use the "grey" wire behind the headlight switch, but I don't want to tap into this till I'm 100% sure it would work.
I think this might be the way to go. The ring around the cig lighter is supposed to come on when the headlights go on but I think my bulb is blown so it currently doesn't. Should still be receiving power though!
« Last Edit: February 08, 2016, 12:37:56 pm by dk16 »
Offline An0NyMOUs
  • A Nuisance
« Reply #9 on: February 08, 2016, 02:14:39 pm »
Yeah my cigarette lighter doesn't illuminate either, in fact it doesn't work at all!
2.0 FSI 4motion
Offline dk16
« Reply #10 on: February 08, 2016, 09:09:31 pm »
I think it's definitely a blown bulb because mine actually used to work. Apparently they can be changed but not sure how easy it is.
Offline An0NyMOUs
  • A Nuisance
« Reply #11 on: February 08, 2016, 09:18:02 pm »
My cigarette lighter doesn't even push in to be able to warm up. So I'm not really worried about it
2.0 FSI 4motion
Offline dk16
« Reply #12 on: February 09, 2016, 09:20:33 am »
Cig lighter not staying down is easily fixed. All you need to do is bend the 2 tab inside in the direction I've shown in the picture. :) Don't bend them too much of course, just enough so it catches when you push it down.
Offline An0NyMOUs
  • A Nuisance
« Reply #13 on: February 09, 2016, 09:22:19 am »
Nah the spring has gone in mine, I should have explained it better.
It freely slides up and down, doesn't click down or stay up, its fooked :) The lighter part itself that is.
Thanks though!
2.0 FSI 4motion
