Author Topic: engine dress up  (Read 17538 times)
Offline Jay_ed30
Re: engine dress up
« Reply #15 on: February 07, 2016, 08:39:24 pm »
This is mine no cover and a good clean
sent from my galaxy s6
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: engine dress up
« Reply #16 on: February 07, 2016, 09:44:54 pm »
Here was mine
Where'd you get those dress up washer kit from as I used to have them on the tt yes my faithful mk1  :signLOL:
Got them from boltsbolts website :happy2:
Thank you kindly  :smiley:
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
Re: engine dress up
« Reply #17 on: February 07, 2016, 10:09:16 pm »
I always worry about cleaning my engine bay in case of water getting in places it shouldn't and shorting something.
Stage "1.5" ED30 [330BHP] Rtech
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: engine dress up
« Reply #18 on: February 07, 2016, 10:35:47 pm »
It's one  :sick: engine bay for certain  :signLOL: the ram.aor does make it look pretty but the bays always need a wipe  :signLOL:
Offline Ricky123
  • -Receive: 27
Re: engine dress up
« Reply #19 on: February 07, 2016, 11:11:44 pm »
If I'm cleaning an engine bay with an open filter like the ram air one above then I wrap a carrier bag round it.
Other than that I make sure the engine is hot. I don't leave it running while cleaning.
I give mine a good spray with neat non caustic tfr. Give it 5-10 mins to work its magic then jet wash off. Pull bag off the filter. Start that car and shut the bonnet so it drys slightly then give it a light spray with auto glym tyre dressing and leave that to dry. You get a good shine with that without leaving much residue.
I've done the above and made 15 year old engine bays look as new.
Never had any issues with water getting in electrics or anything. That was more of an issue on older motors with dizzy caps etc
56 mk5 ed30 3dr
57 mk5 1.9 TDi match
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: engine dress up
« Reply #20 on: February 07, 2016, 11:15:02 pm »
How about water going down the coil packs ? ^^^
Offline Ricky123
  • -Receive: 27
Re: engine dress up
« Reply #21 on: February 07, 2016, 11:15:38 pm »
There's a couple I've done with the above method
56 mk5 ed30 3dr
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: engine dress up
« Reply #22 on: February 07, 2016, 11:16:24 pm »
Looks very nice and clean  :happy2: how do you prevent water from entering the coil pack plug chambers?
R5
Offline Ricky123
  • -Receive: 27
Re: engine dress up
« Reply #23 on: February 07, 2016, 11:18:25 pm »
Coil packs usually have rubber/plastic type seal fitted to stop that or reduce it. Never had more than a couple of drops down mine.
56 mk5 ed30 3dr
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: engine dress up
« Reply #24 on: February 07, 2016, 11:22:16 pm »
Thanks Ricky123 I think mine could do with a good clean.
I don't have that air filter on anymore though.
Did you get the head clean also?.
R5
Offline Ricky123
  • -Receive: 27
Re: engine dress up
« Reply #25 on: February 07, 2016, 11:24:10 pm »
[/quote]Thanks Ricky123 I think mine could do with a good clean.
R5
[/quote]
Do you mean Externally or intake valves?
56 mk5 ed30 3dr
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: engine dress up
« Reply #26 on: February 07, 2016, 11:33:48 pm »
R5
[/quote]
[/quote]me  :stupid: externally thanks can I just use gunk or similar?.
Intake valve I'll need to remove the inlet for that but that's saved for another day  :grin:
Offline Ricky123
  • -Receive: 27
Re: engine dress up
« Reply #27 on: February 07, 2016, 11:48:31 pm »
I've only ever used none caustic tfr. I just pour some in to a spray bottle neat and just spray over everything. I've never even had to use a sponge or brush but I suppose you could if you wanted.
The last one I did was my Jetta tdi. I should have taken before and after pictures. You wouldn't believe the difference it made.
56 mk5 ed30 3dr
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: engine dress up
« Reply #28 on: February 07, 2016, 11:54:52 pm »
I'll have a go at some point as it's nice to keep things clean under there  :smiley:
Yeah thay would have been good to see how clean it came out as these engines do get dusty under there  :signLOL:
May use a light brush for the metal components and TB  :grin:Thanks again
R5
Offline Jay_ed30
Re: engine dress up
« Reply #29 on: February 08, 2016, 10:54:52 am »
I use g101  apc on mine spray it on leave for 5 minutes agitate with a brush then rinse with the engine running.
