Author Topic: 2005 rcd300 to 2007 rcd300 battery drain  (Read 1199 times)
Offline Blackgtiman
« on: February 09, 2016, 10:42:27 pm »
hi all,
Would replacing a 2005 rcd300 with a 2007 rcd300 cause a battery drain? Reason I ask is cause Ive just had to replace the battery!
Offline Nasir
Re: 2005 rcd300 to 2007 rcd300 battery drain
« Reply #1 on: February 09, 2016, 11:30:48 pm »
No
Shadow Blue 2007 GTI DSG (Standard)
Offline Blackgtiman
« Reply #2 on: February 09, 2016, 11:32:31 pm »
ok thanks, could you help with this also? I didn't get this with the old stereo
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0045
   Revision: 00034000    Serial number: VWZ1Z2F1706473
   Coding: 0040400
   Shop #: WSC 01279 785 00200
   VCID: 377D0620464AFD8680-8062
1 Fault Found:
00821 - Antenna 2 for Radio (R93)
            011 - Open Circuit - Intermittent
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: February 10, 2016, 12:42:33 am »
Mate, I'd find the stereo fuse and with a multi meter check to see if your getting any current drain off the fuse as I had this after fitting an after market stereo to my old car. not saying yours is aftermarket but is a possibility.
