November 16, 2024, 02:41:35 am
All Things Mk5
Mk5 General Area
tt ball joints
Topic: tt ball joints (Read 1901 times)
GTI-MATT
Always Involved
-Given: 0
-Receive: 0
GTI-MATT
tt ball joints
February 13, 2016, 07:16:57 pm »
Im currently running alloy s3 wishbones and hubs on my car i was wondering if i could use the oem tt ball joints to be able to adjust the camber with my current set up?
r5gtt
Just look at my post count
-Given: 342
-Receive: 334
Re: tt ball joints
Reply #1 on:
February 13, 2016, 07:26:43 pm »
Yes you can...
GTI-MATT
Always Involved
-Given: 0
-Receive: 0
GTI-MATT
Re: tt ball joints
Reply #2 on:
February 13, 2016, 07:52:14 pm »
Thats great has anybody run this setup? How much degrees negative camber is adjustable? Ive read to not set it anymore than 2 degrees.
Last Edit: February 14, 2016, 04:34:23 pm by GTI-MATT
r5gtt
-Given: 342
-Receive: 334
Re: tt ball joints
Reply #3 on:
February 15, 2016, 01:44:57 pm »
I reckon a competent four wheel aligner will be able to sort the camber out as mine was done by a company in Birmingham called Lodge Tyres and he knew his stuff when it came to this.
fab5freddy
-Given: 238
-Receive: 239
Re: tt ball joints
Reply #4 on:
February 15, 2016, 07:07:48 pm »
Quote from: r5gtt on February 13, 2016, 07:26:43 pm
Yes you can...
No you can't. TT ball joints only fit on TT arms. You'd need aftermarket ball joints like Superpro to go on the S3 arms.
You can get up to about 2.3 degrees negative camber. I used to have this setup but swapped it out to the S3/Superpro setup as the TT Arms gave a bit too much extra track
GTI-MATT
Always Involved
-Given: 0
-Receive: 0
GTI-MATT
Re: tt ball joints
Reply #5 on:
February 15, 2016, 07:49:44 pm »
Lucky i didnt order a pair of ball joints then. Cheers
All Things Mk5
Mk5 General Area
tt ball joints
