Author Topic: Coding Highline Clocks mk5 golf gti  (Read 4741 times)
Offline ruhaleali
« on: February 14, 2016, 04:58:37 pm »
What do I need to do with VAGCOM to get my 2008 gti coded up with highline display. Please shed light and upload a tutorial if you can please.
Thank you.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Coding Highline Clocks mk5 golf gti
« Reply #1 on: February 14, 2016, 05:08:45 pm »
Thank you.
You can't do it with vagcom.on a 2008 golf you will need a specialist to read your cars immobiliser data.
Get in touch with Eddie-NL, Kalu or Olsen-72
Sent from my SM-G928F using Tapatalk
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: February 14, 2016, 05:19:33 pm »
@RetroRaz can vag tacho read the skc off the old and new units?.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #3 on: February 14, 2016, 06:53:40 pm »
@r5gtt
You need vag commander bro.  Do a search for highline faq. I made a document on it i while back
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #4 on: February 14, 2016, 06:56:44 pm »
Dont think you can use SKC on 2008 car
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #5 on: February 14, 2016, 07:07:31 pm »
@r5gtt
Cheers Bro @RetroRaz those ones on ebay good enough?  :signLOL:
Is this what we need to code the clocks in?.
Found a vag commander on ebay  :ashamed:
Allows managing of brand new units (and immobilizer units) where is allowed programming of PIN, SKC, BGW, MAC. Functions are under CAN-TP2.0
²   Most of popular diagnostic requests, identifications, coding, adaptations, DTCs and s.o. Functions are under CAN-TP2.0
Special Functions:
²   Odometer correction in instrument clusters and EDC15x
²   Read Security Access Code/Login WFS
²   Read/program immobilizer data
²   Read/write EEPROM from instrument cluster/immobilizer. All supported clusters CAN/K
²   VAG MMI TV Activation
²   Read/Write EEPROM of Engine Control Units BOSCH VAG-EDC15x, VAG-ME7.1.1, VAG-Cartronic ME7.8, Porsche
²   Key learning buttons for easy usage (not needed security code). Can do component security authorization
²   Key learning Porsche CAYENNE (not needed security code) K+CAN
²   Custom memory reading from different units like ECUs, EZS-Kessy and s.o
²   Reading flash memories EDC16x, EDC15x, ME7x, MED951, MED751 (with next update will be possible programming of flash memories
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #6 on: February 14, 2016, 07:11:41 pm »
Yeah. They only forget to mention - it works on cars up to 2006 lol
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #7 on: February 14, 2016, 07:14:39 pm »
  They actually do lol
Current version 1.4 covers VW/SEAT/SKODA (CAN) up to September 2006 while AUDI covered up to 2007
« Last Edit: February 14, 2016, 07:18:12 pm by r5gtt »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: February 14, 2016, 10:13:39 pm »
@r5gtt ebay item nunber 151041860027
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: February 14, 2016, 10:38:41 pm »
Thanks bro @RetroRaz  :drinking:
