Author Topic: Interior lights keep flickering  (Read 6880 times)
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
« on: February 14, 2016, 09:15:12 pm »
As the thread title suggests, the LED bulbs I fitted about a month ago keep on flickering whilst I'm driving. Been doing it since I fitted them tbh, I just hoped it would stop happening  :signLOL:
Any ideas on what the cause is / ways to fix it?
It's driving me scatty!
Offline Adam0604
Re: Interior lights keep flickering
« Reply #1 on: February 15, 2016, 08:19:07 pm »
Anyone?
Offline bluebert92
« Reply #2 on: February 15, 2016, 09:32:12 pm »
are they the footwell ones?
Offline Adam0604
« Reply #3 on: February 15, 2016, 10:37:35 pm »
Nah the front reading lights in the main, rear reading lights tend to flicker a bit as well.
Hard to tell if as often as the fronts as I'm driving when it happens lol
Offline rumblytripod
« Reply #4 on: February 15, 2016, 10:50:19 pm »
Get better led bulbs, mine did that then started constantly blowing the fuse. Changed with no problems.
Offline Adam0604
« Reply #5 on: February 15, 2016, 11:08:03 pm »
Hmm may ha to consider doing that then.
I bought from the same guy everyone else on this forum has as well
Offline bluebert92
« Reply #6 on: February 16, 2016, 07:01:20 am »
I find each led unit from different suppliers can vary in length between like 5-10mm which obviously effects the fitment and connection of each one, you may have just been unlucky and got some poor fitting ones
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #7 on: February 16, 2016, 08:18:17 am »
It's just the loose connection. Take the bulb out and bend the filament connection on the holder in a bit more and fit the light again. Repeat this process until the light fits snugly.
Buying those Chinese bulbs unfortunately means that whilst driving over rough enough roads they will flicker marginally!
Offline Adam0604
« Reply #8 on: February 16, 2016, 01:05:41 pm »
I do find that when I go over bumps in the road, they tend to flicker more. Even does it when I have the music loud in the car, guess from the bass vibrations.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #9 on: February 16, 2016, 02:21:40 pm »
Next question... Why do you have your internal lights on whilst driving? :signLOL:
Offline Adam0604
« Reply #10 on: February 16, 2016, 06:28:18 pm »
I don't ... That's what I'm saying haha.
They're set to the only come on if door is open option
But when I'm driving the reading lights keep flickering.
Very annoying. I keep thinking cops are behind me  :signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: February 16, 2016, 08:38:18 pm »
I'm really sorry but had to laugh at the op on this as he sounds so funny  :signLOL:  :drinking:
Check you've not damaged the switch.
Offline Adam0604
« Reply #12 on: February 16, 2016, 11:32:51 pm »
 :sad1:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #13 on: February 17, 2016, 08:21:09 am »
Ohhhhh that makes sense! My last gf used to open the visor and turn the light on every single time she got in the car and all I could see in the corner of my eye was a flickering light... The solution was not to fix the light, just put her in the back  :jumpmove:
If it's happening while the button is switched to door only it sounds like a faulty switch. Try bending the filaments first but I would preferably VCDS scan first and last case change the switch!
Offline Adam0604
« Reply #14 on: February 17, 2016, 12:48:52 pm »
I'll give it a crack thanks :)
