Author Topic: Mk5 Golf with power folding mirrors with key remote  (Read 60197 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« on: February 15, 2016, 12:45:34 am »
My friend n4s has explained to olsen-72 [Edit], how to enable power folding mirror with the key remote. Now you can have someone in the UK to code your door controllers as my friend did to both my Golfs. :wink:
Edit
Edit
Note: This only works with 3rd generation door controllers.
Edit: Removed following olsen-72's request.
Offline olsen-72
  • -Receive: 21
  • Redditch
Re: Mk5 Golf with power folding mirrors with key remote
« Reply #1 on: February 15, 2016, 09:24:26 am »
Thats the ori video mate
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Nasir
« Reply #2 on: February 15, 2016, 11:17:27 am »
So how do you do it mate? The last I read you needed to change the door controllers for Leon ones. But it would be great if I can tweak it in VCDS.
How do you know if you have 3rd generation door controllers?
Shadow Blue 2007 GTI DSG (Standard)
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #3 on: February 15, 2016, 11:21:39 am »
That cannot be done with VCDS
For controller version, look on label file in vcds in address 42
« Last Edit: February 15, 2016, 11:23:14 am by olsen-72 »
Offline Nasir
« Reply #4 on: February 15, 2016, 11:23:05 am »
Thanks. I'll stick to using the mirror switch then.
Offline SI-R32
  • -Receive: 126
« Reply #5 on: February 15, 2016, 12:09:48 pm »
its done via firmware changes inside the controller with some aftermarket software possibly VAG CAN Pro, either some clever sod can manipulate the coding or the vag can people provide a new flash for the existing firmware.
or for around 80 quid you can just use a SEAT door module on the drivers side.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #6 on: February 15, 2016, 12:19:57 pm »
I bought a seat door controller, going to try it this weekend.
Offline SI-R32
  • -Receive: 126
« Reply #7 on: February 15, 2016, 01:43:52 pm »
Do you have a 3 door? PITA if you have a 5 door.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: February 15, 2016, 02:17:38 pm »
I have a 5 door. The back doors are locked using the CCM as I have a GEN1 control module.  On my driver door card I have no controls for the rear windows.
I had a read through your guide on r32oc, looks like I wont need to do the metal peice mod for the windows going up and down
I hope its just coding and thats all.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #9 on: February 20, 2016, 01:24:56 pm »
So fitted it today, door mirrors fold on remote, indicators work, haven't checked puddle lights yet. Had an issue with getting thd door to lock, window switch working, lock/unlock button on door , door warning lights and the mirror adjuster. Basically everything on the driver door.
I have a feeling the pin outputs are different on the controller. It might be that the seat door control module i bought is gen2 or gen3.  And my vw one was a gen1.
Going to research it further
Sent from my SM-G928F using Tapatalk
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
« Reply #10 on: February 20, 2016, 01:26:20 pm »
Is yours 3 or 5 door? I'll be doing this soon hopefully. Good work!
VCDS (Preston, Lancashire)
Offline SI-R32
  • -Receive: 126
« Reply #11 on: February 20, 2016, 01:36:47 pm »
that's exactly what it will be, if yours is gen 1 then the SEAT module will be gen 2/3 if you want copies of the wiring diagrams to convert the pin outputs send me an email address i can send a pdf to and i'll fire them over
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #12 on: February 20, 2016, 02:03:23 pm »
its a 5 door but I have manual windows on the rears. Apparently theres not many 5 door mk5's with manual rear windows.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #13 on: February 20, 2016, 02:04:45 pm »
Thanks SI. my email address is hitman_dubz@hotmail.co.uk
Appreciate it buddy
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #14 on: February 20, 2016, 04:06:38 pm »
Little preview here
https://www.instagram.com/p/BCA5utku2r4/
