Author Topic: Mk5 Golf with power folding mirrors with key remote  (Read 60201 times)
postoronniy
Re: Mk5 Golf with power folding mirrors with key remote
« Reply #90 on: March 04, 2019, 07:42:36 pm »
Sorry for bring this up.
I has the 1K0...N door module which dont fold and I know for sure that the same N module with another SW  fold mirrors.
My idea is to copy the software from one module to another. Is it possible? Someone did this !?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #91 on: March 08, 2019, 02:38:27 pm »
It should be possible to update the revision of the module firmware with a VCP cable.
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #92 on: March 08, 2019, 05:40:24 pm »
Revision N fold for sure. In a fact it can fold on remote as well
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline valdikiss@gmail.com
  • Newbie
« Reply #93 on: January 17, 2020, 09:06:41 pm »
Hi,
I have a 2008 Golf mk5.  I installed a pair of electrically folding Golf mk5 mirrors.  The number of control units is 1K0959701Q (793M) and 1K0959702Q (792M).  These are from a Passat B6!  Unfortunately, not everything works perfectly.  The mirrors fold, but the windows do not run automatically.  What can I do? Thx
Offline davtsik
  • Newbie
« Reply #94 on: February 08, 2020, 07:28:34 pm »
Of from what I've read on different forums, I don't think anyone figured out what to change to adapt for an example scirocco, EOS, etc.  modules to run with MK5 window drop distance.
I think this might be a matter of a motor as for example all scirocco do have a different motor part number compared to mk6, if I remember correct.
So maybe issue is within motor and not a module itself ?
Although it is confirmed that MK6 modules work fine without any issues. Obviously rewiring is required to comply with Max Gen modules.
I already have folding mirrors that I need to fit and looking on ebay for modules + motors with correct part number.
PS.
you don't necessarily need a full VCP, you can dump eeprom via eeprom readers and clip into the module directly, modify it and reflash it. [I have somewhere information which reader you would need to use]. Odis should be able to do so as well through downloading firmware, editing it with hex file editor and loading it back into the module. I was going to try it some time ago but got a shed loads of work recently and all car work has to wait, unfortunately.
hi,
Where can i download firmware? I have 1K0959701Q modul. Key does not close the mirror.
Offline Sebas_theFish
« Reply #95 on: January 03, 2022, 05:56:08 am »
Can I just confirm that this works on RHD Mk5? Can be done with VCP one click function?
« Reply #96 on: April 07, 2022, 01:05:25 pm »
So just a little update on this, first i had ordered Van Can Pro copy from somewhere thinking that this would be a wise buy, sadly this wasn't the case but i'll explain a little more soon.
I was trawling through the net when i stumbled across this
http://forum.golf6.pl/mk6-retrofitting/skladanie-lusterek-z-poziomu-pilota-t159-75.html
You'll need a bit of translate but kinda easy to keep up, lots going on but mainly the bits to change in the module etc be it 1K0 or 5K0 but you need a program to interrogate the module and change things, also modules require security access before you can do anything, so i plugged my s**t copy of VCP in only to find it did nothing, i was a little disheartened but thought sod it i''ll buy the fully bloody version.
Now from installing the copy i got an idea what the program is capable of and it already gives you the folding mirror option on a one press solution for 1K0 and 5K0 modules not just N modules.
This afternoon I got my now fully working version of VCP up and running and put my old 1K0 module back in its from 2010, some of you may know I've had a skoda 1T0 module in my car to do the folding mirrors for a few years but i wanted it done properly due to a couple of silly things the 1T0 module does.
Here is the write up i did for that
http://www.r32oc.com/topic/44240-fold-mirrors-with-from-key-with-auto-closure/
So with my 1K0 module in
I pressed a few buttons on VCP and now my mirrors fold with a long press from the key from a golf module and open as soon as i open the drivers door, rather than with ignition which i'd already been used to before from the 1T0 module.
So next step is to see if the 1T0 module will reprogram to fold mirrors upon opening the drivers door?
plus i want to try an older 1K0 module from say 2005 onwards that aren't N versions, obviously they still need the folding option in them to start with it can't make low modules folding.
So if anyone wants me to try coding there mirrors up for FREE please get in touch (i'm in Maidstone area) and we'll experiment to see if it can be done, which i don't see why not.
one last thing the mirror worked the other way round to the passenger side one, which I tried to rectify without swapping the wires over but i had to just swap the wires over in the mirror plug for it to be in tandem. overall a productive and happy day.
one other thing to try i've been collecting 5K0 drivers units from Europe, now putting these on a RHD car makes things all work wrong way round, but VCP also can change modules from LHD to RHD so i'f this works and say your old 1K0 version can't be coded then you could use 5K0 version to see if works.
Can you explain how you did it with VCP because I have genuine VCP and those modules and mine doesn't work...
Offline CraigP
« Reply #97 on: April 07, 2022, 05:13:48 pm »
I know this is a pretty old thread now but I’m hoping I can still find out some information….?
I have a 2008 Golf GT 170 with the folding optional mirrors as standard. Can I get the key hold folding done by just reprogramming or do I need a new module/s and wiring..?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #98 on: April 07, 2022, 11:23:29 pm »
Your module should be fine but it would be better if you could share what part number you have fitted.
« Reply #99 on: April 07, 2022, 11:57:43 pm »
If you GEN 3 MAX N modules apparently it's possible with VCP... That's what I have and it didn't work though. Will put my Mk6 module back in this weekend and see if it works with that.
Sent from my Samsung Smart Fridge
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #100 on: April 08, 2022, 01:04:34 am »
I had this done on both my Golfs (GT Sport and GTI Ed. 30) with these part numbers:
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
Try a different retrofitter.  :wink:
« Reply #101 on: April 08, 2022, 01:37:23 am »
Same part numbers as mine. What software version are yours? Did you code it yourself or take it to someone?
Offline CraigP
« Reply #102 on: April 08, 2022, 08:11:26 am »
I will try and find out the P/N’s.
If I do need to change modules are they plug and plug or do all different modules require some re-wiring aswell..? Anyone in the North West who can do the work..?
« Reply #103 on: April 08, 2022, 01:23:03 pm »
You'll probably have the N version modules same as me. As long as you already have GEN 3 modules they're plug and play but will have to be coded the same as your current ones.
Offline CraigP
« Reply #104 on: April 08, 2022, 01:33:13 pm »
Without sounding stupid, what’s VCP..?
