Author Topic: Mk5 Golf with power folding mirrors with key remote  (Read 58313 times)
Offline RobC
  • -Receive: 20
Re: Mk5 Golf with power folding mirrors with key remote
« Reply #60 on: June 15, 2017, 12:10:33 pm »
Bit of a thread bump - on the assumption I have the correct module (which I will check but I have a 57 plate Edition 30 with Folding Mirrors fitted as standard) - is there anybody in the South/Greater London/Surrey area or nearby that can re-code the modules to enable this?
Cheers.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #61 on: June 15, 2017, 03:53:55 pm »
I think @SI-R32 is right up your street
Offline SI-R32
  • -Receive: 125
« Reply #62 on: June 15, 2017, 09:15:33 pm »
Cheers.
I'd give it a go for you, probably a little bit to far for you to come, could possibly meet you half way somewhere if we can sort something?
Offline Christiank
  • -Receive: 39
« Reply #63 on: June 15, 2017, 09:20:30 pm »
Would also be interested knowing if this will work since I've just fitted Generation 2 MAX modules that allow power fold.
Simon you wrote in a earlier post that you had the tools to invert the software from a RHD to LHD - I've got a pair of Gen.3 MAX modules that I got from a UK car. Installing this made my window work the other way along with the mirror adjustment. So that's the reason I'd go back to a gen.2 setup.
If you need some Gen. 3 modules to test the invert on I could ship mine to you.. They are 701/702 Q motor with 793/792 M electronic.
Offline RobC
  • -Receive: 20
« Reply #64 on: June 15, 2017, 10:10:24 pm »
Cheers.
Perfect Si, sounds good. Ill drop you a Pm.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #65 on: June 16, 2017, 01:40:06 am »
Still need to do my wiring on my car for the seat Leon Gen 3 N modules to have the same if that's correct?.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #66 on: July 30, 2017, 08:40:52 pm »
@si-r32 where are u based mate?
Ive picked up some folding mirrors and noticed my car already has N modules as I have mirror dip on reverse too. Would like them to be folded on key lock if possible.
Thanks buddy
Sent from my SM-G955F using Tapatalk
Offline Eighteen88
« Reply #67 on: July 31, 2017, 12:29:31 am »
I'd be interested in getting this done, am based in the Scottish Borders is there anyone that can help me with this, more than happy to travel.
Milltek Non Resonated Cat-Back exhaust “edition 35”, Forge PCV Delete, APR Stage 1 Remap & APR DSG Remap, Volkswagen racing intake, Volkswagen racingline sport springs, Audi R8 Coil Pack, GFB DV+
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #68 on: July 31, 2017, 02:00:17 am »
 :thinking:
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #69 on: August 03, 2017, 04:32:58 pm »
Mine do this. Fold only, dont unfold
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #70 on: August 04, 2017, 11:37:46 pm »
how do you unfold them? @JoeDarKa
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #71 on: August 05, 2017, 07:22:45 am »
Im sure you put the keys in ignition and it unfolds?
Offline olsen-72
  • -Receive: 21
  • Redditch
« Reply #72 on: August 05, 2017, 11:01:17 am »
2 options for unfold
- with ignition
- with door open
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #73 on: August 05, 2017, 12:01:55 pm »
So ive got N door modules, fitted passenger side folding mirror and tried coding it but got coding rejected error 31 on vcds when i tried adding 4096 to the old number. Any ideas?
Do i need to fit both sides and then code? It started to rain so i couldn't fit the driver one in time.
Offline SI-R32
  • -Receive: 125
« Reply #74 on: August 05, 2017, 12:16:37 pm »
N modules don't need coding with the 4000 number, as that's only for cars later then 2008, N modules have it precoded in to fold.
