Author Topic: vag-com  (Read 2964 times)
Offline tomgregory123456
vag-com
« on: February 15, 2016, 09:36:41 pm »
Hi,
Just bought a mark5 golf can someone explain what I need vag-com for (do I need it for remapping and turning the lights on)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: vag-com
« Reply #1 on: February 15, 2016, 10:31:45 pm »
Hi,
Cant remap using vcds.
You can do extra things like code modules abd diagnose errors.
Loads of info in vagcom sections
Sent from my SM-G928F using Tapatalk
Liam0205
Re: vag-com
« Reply #2 on: February 15, 2016, 10:34:02 pm »
It's primarily a diagnostic kit that allows you to scan the car faults etc but also allows you to change the coding for certain features.
It has nothing to do with remapping and not sure what you mean by lights but I do believe you can alter the coming home light functions and things like that.
It's also known as VCDS these days. Have a look at the Rosstech website for more info
Re: vag-com
« Reply #3 on: February 17, 2016, 06:45:54 pm »
Hi
Thamks for the advance I mean with the lights I've seen quite a lot of vw golfs with dipped and indicators constatley on any ideas????
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: vag-com
« Reply #4 on: February 17, 2016, 08:23:32 pm »
Hi mate, that'll be the bi xenon and xenon headlights that you can set to do this. look at my signiture.
Standard lights cannot do this.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: vag-com
« Reply #5 on: February 17, 2016, 08:33:28 pm »
Standard lights can also do this.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: vag-com
« Reply #6 on: February 17, 2016, 08:36:06 pm »
Oh really  :ashamed: and :stupid:  :signLOL: I thought only the xenons did this. Thanks for the info bro  :drinking:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: vag-com
« Reply #7 on: February 17, 2016, 08:42:26 pm »
Yeah heres a link on how to
http://www.mk5golfgti.co.uk/forum/index.php?topic=57123.0
Personally I wouldn't go over 40%
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: vag-com
« Reply #8 on: February 17, 2016, 09:47:10 pm »
At least it makes to oem lights look a little cooler  :signLOL:
Re: vag-com
« Reply #9 on: February 18, 2016, 05:01:09 pm »
Thank you all the advice is much appreciated.http://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/happy2.gif
Offline V3trox
Re: vag-com
« Reply #10 on: February 18, 2016, 05:33:35 pm »
You can also use it to do data logging. Sometimes helps diagnosing problems
