Author Topic: REVO Stage 5  (Read 8303 times)
Offline DotDotCurve
REVO Stage 5
« on: February 16, 2016, 02:20:58 pm »
Hey guys.
Had my GTI since May 2015. To cut a long story short the plan has always been to work up the Stages but, situations have changed and I may be in the financial position to kickstart it and skip a few Stages.
I can't really find much on Stage 5 for the GTI no matter where I look.
I am not the most mechanically minded person so I apologise if any of the advice of give should be obvious. Treat me like a complete newbie.
Does anyone have an idea how much it would cost (roughly) to go straight from Standard to Stage 5?
Spec list for reference:
 About this Software
 Hardware Requirements
 Order REVO Software
 More software
Hardware Requirements:
3071R External Wastegate Turbo Kit with associated hardware for fitting and installation
RS4/R8 injectors
3.0"Turbo back exhaust without pre-cat and with decat (For Off-Road use only) or highflow catalytic convertor
Cold Air Intake with correctly scaled MAF housing
uprated or additional intercooler (S3 uses larger stock IC but additional IC is recommended)
highflow mechanical fuel pump
uprated intank fuel pump
uprated engine internals (rods, pistons. Revo recommend keeping stock compression)
Uprated Valve-train (to support 8000rpm)
Uprated Engine Mounts
Latest revision factory DV
Uprated Brakes
NGK Iridium Spark Plugs
Uprated Clutch
Hardware Recommendations:
Boost gauge                 -        if you want to run an MBC and over 1.6/1.7bar peak
Wideband AFR gauge      -        for setup purposes
Offline AJG09
  • -Receive: 21
  • My Ride: 2005 mk5 golf 1.6 FSI
Re: REVO Stage 5
« Reply #1 on: February 16, 2016, 03:28:53 pm »
You will also need a nappy  :happy2:  :driver:
Offline DotDotCurve
Re: REVO Stage 5
« Reply #2 on: February 16, 2016, 04:02:53 pm »
Haha not sure if you mean because of the cost or because of the power...... Maybe both!
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
Re: REVO Stage 5
« Reply #3 on: February 16, 2016, 06:26:40 pm »
Will you even be able to get the power through the wheels with that much power ....?
Offline DotDotCurve
Re: REVO Stage 5
« Reply #4 on: February 16, 2016, 06:30:24 pm »
Best I've seen if a 550+BHP 500+lb/ft Stage 5 one. It seemed fine, but obviously had a lot of money spent in its handling and traction.
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: REVO Stage 5
« Reply #5 on: February 16, 2016, 07:26:58 pm »
Hardware list reads about right, for the engine. I'm sure you've got it sussed but lsd, big brakes etc would be a very good idea!
  • -Receive: 427
Re: REVO Stage 5
« Reply #6 on: February 16, 2016, 07:45:13 pm »
Copy and paste list from REVO?  :wink:
Stage 5?? Stage 3 then.
£15k-£30k from start to finish for all mods inc brakes, handling, engine etc etc etc required depending on parts used. APR or Nortech BT kits are £5k+ alone IIRC. Pikey had 500bhp from his Eddy, Hurdy had 500bhp from his Mk6 R. Find thier build threads and trawl through.
Offline DotDotCurve
Re: REVO Stage 5
« Reply #7 on: February 16, 2016, 08:47:13 pm »
Yeah. Copy and pasted so people knew roughly what was needed.
REVO do 5 stages for the KO3.
I'll have a look for their build threads. Thanks :)
Offline flashp
  • -Receive: 65
Re: REVO Stage 5
« Reply #8 on: February 21, 2016, 05:49:33 pm »
I would talk to JKM about circa 500bhp in a fwd. Their Octavia is running 520 currently and they run an ECU from these people: http://www.syvecs.co.uk
I've ridden in it and the delivery is devastating and beautifully controlled. I'd say it's too fast for the road in all honesty but they have it as a technical showcase and a forthcoming 200mph fwd record attempt.
Within this ECU are some very well engineered traction control systems, amongst other's that are non existent in standard ECU's. It will protect your drive train in a way that a standard one simply can't. It will let you do a foot flat launch  without any loss in traction. No spin or wheel hop...just grip. It's a mind boggling experience and I would say it re-writes the rule book for fwd, but it's not cheap.
Done properly this will cost many many £'s.
« Last Edit: February 21, 2016, 06:01:07 pm by flashp »
Gone but not forgotten :-)
Offline leericho
Re: REVO Stage 5
« Reply #9 on: May 28, 2016, 10:06:46 pm »
Stage 5
Yeah they do and the k03 is the first thing to go in the bin......
Deep pockets? If so bin the gti and buy a better base model to start off with
Save you a lot of time effort and monies
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: REVO Stage 5
« Reply #10 on: May 28, 2016, 10:20:32 pm »
Just buy an RS and done with  :signLOL:
Offline Madone
  • -Receive: 27
Re: REVO Stage 5
« Reply #11 on: May 29, 2016, 07:26:45 am »
Are you really going to put at least 5 times the value of the car into mods ??, hope your not a financial advisor by trade ! Haha  :laugh:
If you have 30k to spend you'd be mad to spend it on a 7k golf !, as R5 said just buy a RS, or golf R, they go to 400bhp with exhaust and remap.  :happy2:
