Author Topic: Rainbow IQ 365.19 direct replacement  (Read 3611 times)
Offline white91
« on: February 17, 2016, 07:27:00 pm »
Just picked up set of these NOS, my plans are to fit them, and fit some sound insulation too.
No currenty planning to amp them as I will run them off a 50w head unit to begin with is this the wrong way to go?
Finally what should I do with the rears?
Offline Rob.
Re: Rainbow IQ 365.19 direct replacement
« Reply #1 on: February 17, 2016, 09:38:12 pm »
They'll no doubt work OK, but you won't be getting anywhere near their full potential without amping them properly
I've never been arsed with upgrading rear speakers personally. I sit in the front, and the passengers aren't funding my audio!
Offline white91
« Reply #2 on: February 18, 2016, 10:01:17 pm »
How difficult is it to amp speakers? Don't you run a feed direct from the battery?
For the rears some people seem to just run a woofer and forget the tweeter.
Offline Rob.
« Reply #3 on: February 21, 2016, 08:11:33 am »
Yeh, you'll need to run the correct sized power cable for the amp from the engine bay. Amp's generally go in the boot, but can go under front seat if small enough. Then speaker wires from the amp to the doors through the original rubbers. Taking the exterior door panels will make wiring and sound deadening easier too.
Offline theminty1
« Reply #4 on: February 25, 2016, 08:57:47 am »
3 or 5 channel amp running front speakers and a small sub will transform the sound. Forget the rears. Sound insulation is a good investment but requires door skins off which can be tricky regarding the door handle.
Go to your local car hifi place for some advice. Where are you located? If in Scotland i recommend MF2K in Glasgow.
Good luck  :happy2:
140 BKD GT TDi  5dr
Offline white91
« Reply #5 on: February 25, 2016, 09:21:18 am »
So would I simply unplug the rears?
Where could I place a sub as I don't really want to lose any boot space?
I've used silent cost in the past, and also flashing tape as sound insulation, both seemed to work quite well
Offline theminty1
« Reply #6 on: February 25, 2016, 10:14:24 am »
Ideally replace head unit which gives pre outs to add an amp. Disconnect rears. 3channel Front left and Right and rear sub.
You can get sub boxes built into the side of the boot. You can build a small box then take it in and out as required via a quick disconnector easy :)
As i said make a trip to local car hifi place for advice. Also you can buy 2nd hand amps. Genesis make good stuff.  :notworthy:
Bit of Dynamat Extreme helps. Cuts road noise too
« Last Edit: February 25, 2016, 10:16:06 am by theminty1 »
140 BKD GT TDi  5dr
Offline white91
« Reply #7 on: February 25, 2016, 10:55:02 am »
Yeah I'm about to change the head unit, like the look of the dnx525dab
Amp will have to wait for the moment with new head unit and new speakers plus noise insulation.
I'm keen to do all this myself, partly for cost saving, partly for my own reasons
Offline theminty1
« Reply #8 on: February 25, 2016, 11:26:49 am »
You can use polo 6r base and aerial for your DAB
140 BKD GT TDi  5dr
Offline white91
« Reply #9 on: February 25, 2016, 11:29:22 am »
Do you have a part number? But reluctant to fit a window one tbh.
Think gps aerial will be ok under the dash
Offline theminty1
« Reply #10 on: February 26, 2016, 09:04:49 am »
Pretty sure its these. There are several versions for example if you need GPS or TV
6R0035501A Base (it has two connectors only FM and DAB)
6R0035849A Aerial
Extension cable as you need to run one as just now there is a cable for FM only. You will need to check the adapter at the head unit end
http://www.celsusice.co.uk/shopdisp_6183.php
140 BKD GT TDi  5dr
Offline white91
« Reply #11 on: February 26, 2016, 10:09:42 am »
Cheers mate will check those out
Offline Bigjimknickers
  • -Given: 55
« Reply #12 on: May 23, 2016, 10:04:37 am »
How did you get on with this rainbow set? Very interested in this.
Do you mind sharing where you bought it?
Ta :happy2:
