Author Topic: Loom change for rsap or normal bluetooth?  (Read 1608 times)
Offline fazi123
« on: February 19, 2016, 12:18:14 pm »
Hi guys,
Im installing my mdi kit along with my RCD510. I also have a bluetooth kit (rsap) which I want to upgrade to the unit where I can stream music from etc.
Is the loom the same for both of these? The reason I ask is I can then just install the loom etc now and plug the unit in when I get it.
Thanks,
Faz
« Last Edit: February 19, 2016, 03:05:54 pm by fazi123 »
Offline Pashka
Re: Loom change for rsap or normal bluetooth?
« Reply #1 on: February 20, 2016, 01:56:08 pm »
If your exsisting loom is from the factory with the car it will have only one channel for the sound, need to add two wires for another side to have stereo sound. Except that looms are the same.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline mdmay
  • -Given: 38
« Reply #2 on: March 03, 2016, 08:43:40 pm »
Do you know what wires are needed
Sent from my ONE A2003 using Tapatalk
Regards,
Mike
Offline Pashka
« Reply #3 on: March 03, 2016, 08:56:55 pm »
What did you mean? pinouts or wires itself? 1 pair shielded or any 2 wires.
Offline mdmay
  • -Given: 38
« Reply #4 on: March 03, 2016, 09:56:18 pm »
Pinouts please.  Many thanks
Regards,
Mike
