Author Topic: Yoko AD08R  (Read 19392 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=56d8s0j2augkpmcpbufk9gvtr5&/topic,19740.0.html
Yoko AD08R
« on: February 19, 2016, 11:29:54 pm »
First impressions are that they seem to have roughly the same amount (possible a touch more) of grip in the current damp conditions as my previous MPSS tyres, which i still rate as the best tyre I have used so far.
I wont know what the AD08R are really like until the weather dries up a bit.
Offline Bignod00
  • Ginsters are sh*tE!!
Re: Yoko AD08R
« Reply #1 on: February 20, 2016, 06:24:38 am »
 :popcornsoda:
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Yoko AD08R
« Reply #2 on: February 20, 2016, 07:29:10 am »
Keep us posted on how they are in the wet, i.e. standing water? I can understand them being ok in the cold and damp once you have a little heat in them, but fear they would be bloody dangerous when hitting standing water at speed
Is the load rating high enough, especially given the lower speed rating? Standard is 92 and the higher Y rating....
« Last Edit: February 20, 2016, 07:31:32 am by Dan_FR »
Re: Yoko AD08R
« Reply #3 on: February 20, 2016, 07:48:43 am »
The sidewalls are stiffer than most 92xl anyway. w speed rating is more than enough for 99.999999% of usage
88W vs 92Y
168mph vs 186mph speed rating
560kg vs 630kg load
Both fall in the limits of the GTI
« Last Edit: February 20, 2016, 07:58:06 am by rich83 »
Offline Mitch H
  • -Receive: 25
Re: Yoko AD08R
« Reply #4 on: February 20, 2016, 08:30:50 am »
have you tried toyo 888's?
im between trying mpss or a semi slick like ad08r or toyo888 for my next tyre.
with summer coming up semi slicks are very tempting !
Re: Yoko AD08R
« Reply #5 on: February 20, 2016, 08:41:11 am »
 :popcornsoda: :popcornsoda:
Offline Johnsy
Re: Yoko AD08R
« Reply #6 on: February 20, 2016, 10:07:12 am »
88W vs 92Y
560kg vs 630kg load
Could be enough to void your insurance in the event of an accident if the minimum manufacturers recommendation is 92y.
given the weight of the car and the nature of what this tyre is for,you'll be exceeding its load rating.it may not go pop so to speak,but you might find uneven/excessive wear or the tyre deforming .
Offline Johnsy
Re: Yoko AD08R
« Reply #7 on: February 20, 2016, 10:11:29 am »
The Michelin pilot sport cup 2 in 225/40/18 is the same price as those you've mentioned, and around £20 more a corner than the MPSS which is tempting me right now
Re: Yoko AD08R
« Reply #8 on: February 20, 2016, 12:12:19 pm »
88W vs 92Y
560kg vs 630kg load
They are find for the weight of the car...
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Yoko AD08R
« Reply #9 on: February 20, 2016, 03:52:33 pm »
88W vs 92Y
560kg vs 630kg load
Do you have any actual proof of this, rather than just your opinion based on some simple maths based on the weight of the car, not the load generated under extreme braking and cornering forces? Sidewall stiffness is irrelevant to the structural strength, which is given as a load and speed rating
Fitting sub standard tyres, i.e. tyres that are lesser rated than OE, is grounds for void insurance and/or prosecution in the event of an accident
Re: Yoko AD08R
« Reply #10 on: February 20, 2016, 04:19:51 pm »
The load rating of tyres is given as static weigh loads.
And the fastest I go is 70 so 168mph covers that fine.
Re: Yoko AD08R
« Reply #11 on: March 14, 2016, 11:23:30 pm »
Small update.
Grip is good. They do however seem a little less grippy than the MPSS from cold, but that is to be expected. They are much happier today in the slightly warmer weather. Once it gets a bit warmer they will be incredible.
They do have a tendency to slightly tramline. Very slightly, but noticeable on certain roads.
Re: Yoko AD08R
« Reply #12 on: April 01, 2016, 03:01:01 pm »
So much grip in the dry, hilarious amounts of fun.... these really are a step up on the PSS.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Yoko AD08R
« Reply #13 on: April 01, 2016, 05:58:24 pm »
Is that once warmed up a little or from the get-go?
Re: Yoko AD08R
« Reply #14 on: April 01, 2016, 06:17:59 pm »
Id say once warmed up. They just feel fantastic when you push hard. I think overall they definitely suffer due to the stiff sidewall in terms of NVH over the PSS, which makes the ride harder.
But we all know... its about grip. Ill suffer the increase in noise as a trade off to silly amounts of grip
