January 01, 2025, 07:33:44 pm
All Things Mk5
Mk5 General Area
auto dimming mirror
Topic: auto dimming mirror (Read 1850 times)
mogga69
Just Arrived
-Given: 0
-Receive: 1
mossy
auto dimming mirror
February 21, 2016, 08:42:52 am »
hi there I have a 2005 gti and the mirror has stopped working ive changed the fuse and theres still no green light on the mirror any ideas
Candy White 5 Door
Pioneer Sat Nav / Pure white dsg park assist apple connect ordered
Carpy25
Always Involved
-Given: 11
-Receive: 40
Re: auto dimming mirror
Reply #1 on:
February 21, 2016, 10:51:35 am »
Silly question but you've not turned it off have you the button is on the lower rear of the mirror in the middle easy to turn off when you adjust it
I know I've done it
Rob
mogga69
Just Arrived
-Given: 0
-Receive: 1
mossy
Reply #2 on:
February 21, 2016, 06:37:43 pm »
hi there tried the button nothing there no green light I assume its buggered thanks for responding back
Candy White 5 Door
Carpy25
Always Involved
-Given: 11
-Receive: 40
Reply #3 on:
February 21, 2016, 09:27:24 pm »
I would check the fuses again just in case there's two feeding the mirror as there's not really any lightly hood of something moving about to break a wire feed and assuming you've not had a screen replaced recently a fuse would be the expected culprit
I've looked on line and some say fuse 4 some say fuse 5
same fuse also runs heated seats, multi steering wheel and air con are these working? if they are then next check would be to swap it out with someone else
on the plus side these are not overly expensive and you can shop about until a cheap one pops up on the bay
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2060353.m570.l1313.TR0.TRC0.H0.Xauto+dimming+rear+view+mirrow+mk5+golf+gti.TRS0&_nkw=auto+dimming+rear+view+mirrow+mk5+golf+gti&_sacat=0
Rob
Last Edit: February 21, 2016, 09:29:10 pm by Carpy25
mogga69
Just Arrived
-Given: 0
-Receive: 1
mossy
Reply #4 on:
February 21, 2016, 10:02:56 pm »
cheers bud will try swapping in the morning really miss this on dark evenings
Candy White 5 Door
All Things Mk5
Mk5 General Area
auto dimming mirror
