Author Topic: How often should the spark plugs be changed?  (Read 5958 times)
Offline Lewo
« on: February 22, 2016, 11:14:53 am »
I've been looking through the Main Dealer service history for the car and it looks like they were last changed in July 2012 nearly 50k miles ago... :surprised:
Is that normal? Mind you they were £12 a pop!
Think I'll get them changed in the pre map things to do so what plugs do people use, VW or other?
Offline Flyingscotsman
Re: How often should the spark plugs be changed?
« Reply #1 on: February 22, 2016, 12:19:05 pm »
Plugs are supposed to be changed at major service (every 20,000 miles) or every other year if miles low.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=92imnpg5ihtlql627qepec5fp8&/topic,19740.0.html
« Reply #2 on: February 22, 2016, 12:50:13 pm »
Actually its 60,000 miles if you look in the handbook. Most people do either 10k or 20k depending on useage.
« Reply #3 on: February 22, 2016, 01:05:25 pm »
Never, looked in the handbook, but 60k for a plug change sounds ridiculous.
VW state that plugs are changed at the major service (20k miles or 2 years).
http://www.volkswagen.co.uk/owners/servicing/fixed-price-servicing
Offline dronners
« Reply #4 on: February 22, 2016, 01:15:33 pm »
as a rule of thumb.. if a car is tuned service schedules should be halved.  if theyre platinum/iridium plugs your usually good for 3-4 years. anything else tbh is so cheap and easy to do id just recommend doing them every year
Offline Lewo
« Reply #5 on: February 22, 2016, 04:32:18 pm »
I very much doubt if I'll be getting the car serviced at the main dealers from now on, probably an independent but it'll be done once a year and reckon I'll do 12k per year so which plugs should I get bearing in mind I'll be getting a stage 1 done at Rtech?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #6 on: February 22, 2016, 04:41:53 pm »
NGK BKR7EIX
Only 30quid a set. I change mine annually. Probably overkill but i run meth, and its hardly breaking the bank when you fit them yourself
Offline Lewo
« Reply #7 on: February 22, 2016, 05:55:18 pm »
I've had a look in the service book and yes it says 60k change interval..... :surprised:
