Author Topic: Alarm not working  (Read 8202 times)
Offline kam
Alarm not working
« on: February 25, 2016, 01:34:33 pm »
Guys the alarm on my mk5 gt tdi stopped working I changed the alarm siren for a second hand unit which the breaker tested but fitted it and still nothing do I need Vag com to activate it or should it just work?
Also could it be something else fuse??-any help would be appreciated thanks
Offline skard
  • -Receive: 245
Re: Alarm not working
« Reply #1 on: February 25, 2016, 06:35:47 pm »
Did you see him test it? A used one that has been sitting getting no charge is probably dead also.
Yes VCDS will tell you what is up.
Could be a fuse, wiring, faulty door/bonnet/boot module so the car doesn't actually think it is locked
Offline kam
« Reply #2 on: February 27, 2016, 04:01:31 am »
Offline skard
  • -Receive: 245
« Reply #3 on: February 27, 2016, 08:19:02 am »
http://wiki.ross-tech.com/wiki/index.php/01134
He needs to go into 46-convenience and open measuring blocks, it is there what tells you current status of the sensors and siren
« Last Edit: February 27, 2016, 08:24:48 am by skard »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: February 27, 2016, 08:27:02 am »
Saw this once on a customers car. Turned out to be a fuse,
Check fuse 35, should be 5amp
Sent from my SM-G928F using Tapatalk
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: March 02, 2016, 05:10:29 pm »
Any luck?
Offline kam
« Reply #6 on: March 02, 2016, 10:15:19 pm »
Ok test update I liked in the fuse box in the car and there were a number of spaces left don't know what made me do it but I placed a fuse in the empty spaces and hey presto the siren worked but not properly which indicated the second hand siren was knackered .
I tried the old siren and that didn't work either so I bought a new one and it works the interior sensor is working to .
But I want to know if the alarm should be self arming with a delay if you forget to turn it on ??
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #7 on: March 03, 2016, 09:11:34 am »
It doesn't self arm, only if you have unlocked the car by mistake after arming it. It will then self lock and arm
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #8 on: March 04, 2016, 08:16:53 am »
It's the alarm unit, under front wing.
DO NOT buyt second hand......totally false economy!
I had exactly same three errors.
Bought new from TPS.....fitted....all working fine now!
Main reason I noticed it not working, but wanting it working, was due to enabling unlock / lock chirp :D
« Last Edit: March 05, 2016, 03:11:12 pm by ady-uk »
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: March 04, 2016, 09:49:51 pm »
I have the exact fault code as op has. Alarm not working interior sensor etc.
