Author Topic: Cam Chain Replacement  (Read 4065 times)
Offline raptor_tom22
« on: February 25, 2016, 09:08:06 pm »
Hi all
I'm going to be replacing the cam chain on my GTI in the next few weeks, apart from the obvious tensioner, cam follower are there any other parts people recommend to replace/upgrade while it's partly stripped?
Thanks for your help ☺
Sent from my SM-G925F using Tapatalk
Offline richtung
  • -Receive: 56
Re: Cam Chain Replacement
« Reply #1 on: February 25, 2016, 10:02:52 pm »
You are talking about a MK5 GTI right? (serious question) - the MK5 has a cambelt....
Change the water pump whilst you are at it.
Rich
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=8cerpljoarpdhkdu92epos690o&/topic,19740.0.html
« Reply #2 on: February 25, 2016, 10:08:47 pm »
OP is talking about the chain that links the cam shafts  :smiley:
Offline doylebros
« Reply #3 on: February 25, 2016, 10:09:32 pm »
Rich
Mkv GTI has a cam chain as well as a timing belt. :happy2:
Offline doylebros
« Reply #4 on: February 25, 2016, 10:12:27 pm »
Hi all
Thanks for your help ☺gh
The correct tools cause the locking bolt is fu*king tight and a good power bar.
Also a long reach T30 cause one cover bolt is tricky if you've not got a long reach bit.
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #5 on: February 25, 2016, 10:14:24 pm »
Rich
It's should be a lifetime item, but if/when you get that dreaded startup rattle then it's time to look into getting it changed.
Offline richtung
  • -Receive: 56
« Reply #6 on: February 25, 2016, 10:19:06 pm »
Shh I knew that Rich!!  :ashamed:
Everyday is a school day!
« Reply #7 on: February 26, 2016, 01:11:00 pm »
Thanks for the reply all, already got the water pump cam belt kit and can chain kit on order. Will be changing the cam follower as well even though it was only changed 20000 miles ago. Unfortunately need to change the steering rack at the same time
Offline Panthera
« Reply #8 on: February 28, 2016, 06:32:35 pm »
I have that startup rattle also and that 'rattle' is slightly audible at tick over.  How much for that to be replaced at Mr VW?
2007 Blue Graphite Golf GTi
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
« Reply #9 on: February 28, 2016, 08:13:34 pm »
Best part of £1000 no doubt
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline JamieP86
« Reply #10 on: February 28, 2016, 09:33:50 pm »
As above, realistically you're looking at £1000 + with regards to most cam chain replacements.
« Reply #11 on: February 29, 2016, 09:36:23 pm »
1000 quid for cam chain? doubt it. Should be easily sub £500
Offline Pesky jones
« Reply #12 on: February 29, 2016, 10:31:39 pm »
The rattle associated with cam chains is normally only audible once the engine is warm, with the oil being more viscous hence the noise being more audible. I am not advising against getting it changed if you are concerned however!
