Author Topic: URGENT oil pressure stop engine  (Read 206216 times)
Offline callis
« Reply #15 on: February 27, 2016, 04:41:19 pm »
i had the same issue, Oil light, stopped right away, checked oil and coolant was fine. Started again but rattling. so turned off. Lucky i was about 500 metres away from a garage so started and drove very slowly to them.
They confirmed it, cleaned, flushed and since then 12 months been fine.
Only issue you have is how far you went and how hard with light on, and also fact it now wont start, that said its a starting point and hopefully the issue
05 GTI 5 Door, sunroof, met paint, 18" monza, Leather Anthacite, front centre armrest, xenon headlights, Lux pack 2, Sensors, Winter Pack.
Offline Pesky jones
« Reply #16 on: February 27, 2016, 04:52:01 pm »
@callis  Did you get the p0011 code at all?
True, it is a good starting point fingers crossed
Offline callis
« Reply #17 on: February 27, 2016, 04:55:45 pm »
Tbh didnt get it scanned buddy
Offline Pesky jones
« Reply #18 on: February 27, 2016, 04:58:02 pm »
Ok how much did you pay if you dont mind
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #19 on: February 27, 2016, 05:16:09 pm »
If that's the case then great news bud. £200 parts labour ready to hand then.  :happy2:
Offline Pesky jones
« Reply #20 on: February 27, 2016, 05:19:46 pm »
Now I'm worried about the possibility the engine has seized.
When I tried turning it back on, it just made a whirring noise and the RPM needle only went to about 300 rpm and refused to kick into life. Could it really happen that quickly? With me driving a total of around 500 yards (including the engine being turned off and on again) from seeing the warning light...
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #21 on: February 27, 2016, 05:31:43 pm »
from what you're saying that whirring could relate to the low oil pressure so try the cheapest option first.  oil pick up pipe fresh oil of course and go from there.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=g6ug7hc76brb2v64c7pqlf99s0&/topic,90967.msg917089.html#msg917089
« Reply #22 on: February 27, 2016, 05:35:25 pm »
Oil pickup pipe is not to difficult you will need a long ball head allen key as a couple of the bolts are awkward.
05 | Tornado Red | DSG
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=g6ug7hc76brb2v64c7pqlf99s0&/topic,19740.0.html
« Reply #23 on: February 27, 2016, 05:38:09 pm »
Where abouts are you based Pesky?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #24 on: February 27, 2016, 05:38:42 pm »
You tell him dazz :happy2:
The three bolts in between the bell housing will be the awkward ones  :signLOL:
« Last Edit: February 27, 2016, 05:41:56 pm by r5gtt »
Offline Pesky jones
« Reply #25 on: February 27, 2016, 05:47:46 pm »
I think you guys are right I should definitely try the cheapest option first. Ill look into doing it myself.
Is it right that I would just hear single clicks opposed to  the whirring if the engine had seized as the starter motor cant do anything at all?
« Last Edit: November 23, 2016, 11:32:15 pm by Peskyjones »
« Reply #26 on: February 27, 2016, 05:50:06 pm »
It should turn over. Chances are your battery is flat if it wont crank. Test the battery voltage
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #27 on: February 27, 2016, 05:55:51 pm »
I wouldn't start it to cause more issues  :stupid:
Offline Pesky jones
« Reply #28 on: February 27, 2016, 05:58:02 pm »
I thought turning over was everything up till the engine starts. it just kept the rpm needle at about 300 and just stayed there, whirring. Kind of like it does when I start it normally, but without actually starting.
I wont try to start it again untill ive done the oil. Will it know its "fixed" when everything cleaned and has oil in it and start nornally ?
« Last Edit: March 02, 2016, 09:59:22 pm by Peskyjones »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #29 on: February 27, 2016, 06:03:51 pm »
Once you've replaced the oil pipe it will send oil upto the head and run sh*te for a few seconds and then run better hopefully.
