Author Topic: URGENT oil pressure stop engine  (Read 205693 times)
Offline Pesky jones
« Reply #465 on: March 29, 2016, 07:30:00 pm »
Yeah  :happy2:Just checked everything is at tdc and the tool has gone in nicely. Now to fit new tensioner and adjustor back. Which do people do first, tensioner, and then adjuster and chain or chain and adjuster first?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=evv28v6uq4hrkat2701qvbboep&/topic,90967.msg917089.html#msg917089
« Reply #466 on: March 29, 2016, 07:47:03 pm »
Great! Tensioner then the chain and adjustor go on the same time.
Hook the chain over the inlet cam then put the adjustor into the chain and try and get the pin in the adjustor to pop into the notch on the cam. I got paranoid and marked the chain i also tried moving the adjustor one tooth each way of what i marked and could not get it on.
05 | Tornado Red | DSG
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=evv28v6uq4hrkat2701qvbboep&/topic,19740.0.html
« Reply #467 on: March 29, 2016, 07:47:19 pm »
I think you do the tensioner first (leaving the pin in) and then fit the chain and adjuster... bolt it up and remove the pin from the tensioner.
^^^^ beat me to it.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #468 on: March 29, 2016, 07:49:55 pm »
^^^^ beat me to it.
I forgot to mention the pin though  :ashamed:
Offline Pesky jones
« Reply #469 on: March 29, 2016, 07:51:24 pm »
Cheers guys. Yeah thats what ive been trying but failing for the last ten minutes haha. Il keep trying. That pesky notch
Offline doylebros
« Reply #470 on: March 29, 2016, 07:52:38 pm »
It's fitting and we all have our own methods for me you've got the adjuster out of the way slip the chain over the inlet sprocket then put the chain on the adjuster sprocket and nip the holding bolt up by hand next position tension in place and secure holding down bolts.
If all goes to plan you'll be ready for releasing of the tensioner locking pin and torque all items up and ready for baring over by hand.
Offline doylebros
« Reply #471 on: March 29, 2016, 08:02:45 pm »
Make sure the oil passageway to the tensioner is clear before fitting the tensioner Pesky.
Here's the torque values
Torque specs are the following All are ft lbs.
Cam adjuster bolt is 15 lbs plus additional 1/8 turn
Tensioner bolt is 7 lbs
Valve cover bolts are 7 lbs.
Cam chain case cover is 7 lbs
hpfp bolts are 7lbs
banjo bolt on fuel pump is 13 lbs
union nut on hpfp is 18 lbs
« Last Edit: March 29, 2016, 08:05:11 pm by doylebros »
« Reply #472 on: March 29, 2016, 08:24:34 pm »
what wrench are you guys using to get 7ftlbs and 15 ftlbs?
Offline doylebros
Offline Pesky jones
« Reply #474 on: March 29, 2016, 08:40:34 pm »
Im starting to think somethings wrong with the timing, I can't get the adjuster back on! Ive marked it and found a reference point and its got to be less then a mm off. I don't really get it, unless it is on! It doesnt feel like its sitting right though. Im thinking I might line it up so its nearly in, take the cam locking tool out and adjut the inlet camshaft slightl with the wrench to get it in.
Hope its nothing serious!
« Reply #475 on: March 29, 2016, 08:40:57 pm »
Is the ribe bit for the adjuster 1/2" drive? If so ill need an 1/4 to 1/2" adpater?
Offline Pesky jones
« Reply #476 on: March 29, 2016, 08:41:56 pm »
Yeah it is 1/2 rich but youll loose torque through adapters I think
Offline doylebros
« Reply #477 on: March 29, 2016, 08:44:39 pm »
 :happy2:d
You'll change to a bar with I/2 drive to do the angle.
Offline doylebros
« Reply #479 on: March 29, 2016, 08:48:05 pm »
:happy2:d
And this?
http://www.ebay.co.uk/itm/Neilson-Torque-Angle-Guage-Head-BoltsTighten-Degrees-1-2-Drive-Tighten-2A-/281061180737?hash=item41708d4541:g:UWAAAOxy-WxTE1pR
Sorry pesky....  :signLOL:
I just mark it up by eye pull to my mark - got the angle gauge(different make) just find it gets in the way.
