Author Topic: URGENT oil pressure stop engine  (Read 205622 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ks11le894nnogoe65cshoo8f02&/topic,19740.0.html
« Reply #585 on: April 05, 2016, 11:26:09 pm »
Those valves are not cheap.
Contact Andre Worthington on the TFSI group on facbook... IIRC he can get them cheapish
Offline Pesky jones
« Reply #586 on: April 05, 2016, 11:27:05 pm »
I think they're around ninety quid
« Reply #587 on: April 05, 2016, 11:28:28 pm »
Offline Pesky jones
« Reply #588 on: April 06, 2016, 09:31:22 am »
Heres the oil pool on the gearbox. Prettt sure its coming from directyl above as the wiring loom is covered and there isnt oil beneath the cam chain cover. Hopefully it isn't coming from the metal plate that attached to the vacuum pump. I had a go at taking the vacuum pump off to look for the tensioner plastic. Struggled to get it off completely, but I will do this time. I've also just remembered that I think it was missing one of its three bolts  :surprised: I bet its this causing the leak. I guess I need a new bolt as well.
Hoepfully the vaccum pump gasket will solve this.
I don't need to remove the valve cover to remove just the cam chain cover do I? Just HPFP...
« Last Edit: April 06, 2016, 09:49:01 am by Peskyjones »
« Reply #589 on: April 06, 2016, 10:02:28 am »
Interesting, but progress being made!
Plug in your VCDS and see what the cam position at idle is.  Measuring block 91 iirc.  Should be 28 degs (or KW, german for degrees).
Offline Pesky jones
« Reply #590 on: April 06, 2016, 10:04:53 am »
I've also heard the measuring block is 90, also dan_fr said it could be 93
I guess I could just log them all and check the numbers are all close to each other
The n205 valve is arriving tomorrow, shall I log the blocks after replacing this, will it make a difference?
« Last Edit: April 06, 2016, 10:47:22 am by Peskyjones »
Offline Pesky jones
« Reply #591 on: April 06, 2016, 11:09:07 am »
Could the n205 valve cause the misfires? Is it worth using VCDS to check which (if not all) cylinder is misfiring?
« Reply #592 on: April 06, 2016, 11:09:59 am »
Defo worth doing that yes.
Offline Pesky jones
« Reply #593 on: April 06, 2016, 11:14:22 am »
Ok will replace the n205 valve and log misfires and also the timing blocks tomorrow.
« Reply #594 on: April 06, 2016, 11:14:59 am »
I'm not sure about the N205 causing misfires, hence reading the blocks as it currently stands.   If it's showing actual and requested as 28KW, then that's standard and won't be the cause of the misfires.
Offline Pesky jones
« Reply #595 on: April 06, 2016, 11:20:51 am »
Ok ill do the logging tonight then.
http://www.ross-tech.com/vag-com/m_blocks/090-098.html
Theres quite a few blocks there to measure. Which should I do? If I just go on adv measuring blocks and select them all, I wont have to log anything, I can just read them live, right? Same with misfires on the cylinders. Think I can select each cylinder to see.
Offline Nasir
« Reply #596 on: April 06, 2016, 11:24:08 am »
The terminal 30 fault is caused by removing the battery cables. A lot of these faults will simply be because you've disconnected so many things. Save fault codes, clear them and check again.
Shadow Blue 2007 GTI DSG (Standard)
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #597 on: April 06, 2016, 11:31:47 am »
Block 91 is what you need - I always remember it's early 90's but its pretty obvious when you browse through them. You get a specified and an actual number, and they should match within a degree or so.
« Reply #598 on: April 06, 2016, 11:41:39 am »
Thats for the cam timing yeah?
Offline Pesky jones
« Reply #599 on: April 06, 2016, 11:47:00 am »
Yeah. 91 does 1 camshaft, and 92 does the other. I assume 91 is inlet camshaft @Dan_FR ? I think the n205 valve affects the inlet camshaft timing somehow?
